Results 1 to 7 of 7
Thread: Quick plumbing verification
    Sep 2011
    Montgomery Texas
    89
    My guys are doing the plumbing today and I'm telling them 2.5" from each of my 2 skimmers to the pad and 2.5" on the 6 returns. Also 2.5" to each of the 2 loops in the spa. Each loop contains 6 jets. The higher loop will run off my inteliflow and switch like a normal spa. The second loop wil run when I hit high flow in my intelli touch. Then a second pump with blower will come on and power the second loop. This will not go through the heater. It's just for additional flow and power. The spa is 10x10. I was thinking that 2.5" will be sufficient for this application due to the separate runs. Pad is around less than 60 feet away. Thanks in advance Steve.
    Also separate suction for the two pumps in the spa.
    24X38'ish 23,500 gallon Geometric with 10x10 spa(12jets), Pentair IC40 SWG, Pentair intelliflow(pool-spa), pentair whispersflow 2HP(booster spa jets), Two Polaris 1.5 Hp blowers, Pentair Wisperflow XF 3HP(2 6 foot water falls), Pentair clean&clear plus 520, Pentair Master temp 400. Intelli PH acid dispenser, Intellitouch with iPhone and iPad control. Two 45000 BTU fire bowls and one 60000 BTU fire pit.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Quick plumbing verification
    For the pool, 2.5" is plenty big but for the spa, it depends on the type of jet you use. Higher flow jets require larger pipe and pumps. If you are using 15 GPM jets (3/8"), then 2.5" is probably big enough as long as you don't have a lot of fittings/bends along the 60' run. 3" would give a stronger feeling jet and a little margin to play with. The increase in cost is small but increasing the pipe size later is huge.
    But if you are using the more common 7/16" jets which require 20 GPM, then you may need to add another pump for just the jet loop. I think I recommend that earlier. It is a really bad idea to have the jet loop going through the filter, heater and valves which not only adds a lot of head loss and reduces the flow rate but having a high flow rate through the filter may cause damage over the long run. Plus without the pad equipment you can easily get 20 GPM but with it, you are limited to around 18 GPM which would be a weak feeling jet.
    So I would highly recommend a three pump system for what you are trying to do. But if you are dead set against that, at the very least have the PB plumb an automatic bypass so that most of the water is bypassed around the pad equipment when spa mode is selected.
    Mark
    Sep 2011
    Montgomery Texas
    89
    Ok I think I get what you saying now I some how missed the part about three pumps. I need to look at my schematic again to figure this out. thanks mark. Steve
    Sep 2011
    Montgomery Texas
    89
    Hey mark I'm making a plumbing schematic and have a question about my skimmers. I'm doing 2.5" independent runs to and from the pad. On the suction, when I get the two separate runs back to the pad is ther a best way to hook them to the equipment. Plz forgive my ignorance! Steve
    mas985's Avatar
    Pleasanton, CA
    11,737
    Something like the following diagram would work fine. If you don't have main drains you can eliminate that valve. Have you decided on three pumps or just two? With only two pumps, you will need a bypass valve before the filter connecting directly to the spa jet return. You can automate that in tandem with the spa mode valve.
    Mark
    Sep 2011
    Montgomery Texas
    89
    I think we are going to do three but are considering two. I sent you post to the pb and said make it happen. Thanks for the drawing.
    Sep 2011
    Montgomery Texas
    89
    Thanks again for the post mark that helps me a lot. I think we are going to do two pumps for the spa. I already have four pumps as it is. I'm going to due the bypass valve I'm going out side now to tell them how I want it done thanks again.
