Results 1 to 9 of 9
Thread: Help for New Pool Filter That I Don't Understand
    Just moved into a home with a SWG pool and a Sta-Rite System3 filter. Best guess is that this pool is similar in size to my prior pool (30,000 gallons) but that's completely my guesstimate. Can't lay my hands on any documentation. As you can see from my signature, I have had a pool, but really feel like I am starting from scratch with so many new components, none of which I really understand.
    I went out to look at the filter and this is what I saw:
    Sta-Rite Model = # S7M120
    Max PSI = 50 psi (running about 12psi right now per gauge)
    Filtration Area = 300 sq ft
    Basic question is "How do I care for this filter?"
    I can't immediately see any valve/controls to allow me to backwash. What am I missing? Thanks.
    Howard
    20,000 Gallons
    Cartridge/SWG
    Gunite
    Memphis, TN
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: Help for New Pool Filter That I Don't Understand
    First of all, thanks so much for the manual.
    As I read it, this is the extent of my day-to-day maintenance:
    Weekly Inspection:
    1. Skimmer basket - remove debris.
    2. Stop pump, release all pressure. Remove trap cover
    and basket, remove debris.
    3. Bleed air from filter each time system is started.
    4. Check pump for leaks. If found, see pump owner’s
    manual.
    5. Check pump strainer lid for tightness. Do not overtighten!
    This sounds almost too good to be true. No backwashing?
    I read the manual and it says to clean filter whenever pressure rises 10psi from initial operating pressure. I really don't know what my initial operating pressure was (mentioned above that it is about 12psi now). Any suggestions on when to clean?
    Thanks again.
    Howard
    20,000 Gallons
    Cartridge/SWG
    Gunite
    Memphis, TN
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    Instead of Backwashing, you'll need to clean the filter elements when the pressure rises just like any other cartridge filter.
    Chem Geek wrote a good article on this.
    http://www.troublefreepool.com/how-t...ter-t4465.html
    Glad you like the Cartridge. Almost seems personal what people like, filter wise. What did you have before a Sand or DE?
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Puffin's Avatar
    Jul 2010
    217
    I found a little Youtube video on a similar series to yours. Its from some pool company that is also selling stuff, disregard the ads. It seemed like it might be helpful, to see an overview of the process.
    http://www.youtube.com/watch?v=McoiC-u8-_0
    Richard320's Avatar
    Jan 2010
    18,966
    Quote Originally Posted by HowardL
    Thanks again.
    Howard
    Now. Then you'll have a baseline. Plus it's only going to get colder, and I can't imagine cleaning a filter without getting splattered some.
    Good points one and all. Especially the wisdom about cleaning before it gets too cold.
    The video is very helpful too. Had sand filter before. Thanks.
    Howard
    20,000 Gallons
    Cartridge/SWG
    Gunite
    Memphis, TN
    So, another 18 months have come and gone, and I've cleaned these cartidges a few times ( about 4 or 5) since I originally posted this topic. But I'm now suspicious that it might be time to replace the cartidges. While I didn't install it, I believe the cartidges are at least 5+ years old right now.
    My filter pressure isn't rising but my pool just isn't getting as clean as it should.
    I'm getting a lot of very fine "dust" in my pool that sits on the bottom, is immediately dispersed into the water if I brush it or if the polaris cleaner runs over it. But I just can't get rid of it. The polaris bag has a mesh bag that is way too loosely woven to capture this stuff, and it doesn't seem to be captured at all by the filter.
    Plus, I've just replace my original salt cell with the Optimum T-Cell-15 and with the transparent casing I can actually see stuff that gets past the filter making it into my salt cell. And from there it's back into the pool.
    Any other suggestions? I'm not excited to be buying another replacement item, but I guess 5+ years or so might be the working life of these cartidges. Any suggestions or advice appreciated. Thanks.
    Howard
    20,000 Gallons
    Cartridge/SWG
    Gunite
    Memphis, TN
    22,537
    5 years from the cartridges is a pretty good life, but I'd inspect them real well for splits before replacing them.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
