Thread: Best time of day to filter
    Apr 2011
    Yelapa, Jalisco, Mexico
    25
    Is there a "best time of day to run your pump"? to achieve the best filtering? I have a sand filter.
    10,000 gal, IG, small tile on total pool, Interwater Sand, 2 hp hayward EcoStar variable sp
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Best time of day to filter
    For best filtering it really doesn't matter. If you have a SWCG it is recommended that you run it during daylight hours to keep the chlorine level up. If you have different electric rates run it when the rates are cheaper.
    Here's some reading:
    http://www.troublefreepool.com/pool-.../pump_run_time
    http://www.troublefreepool.com/when-...es-t37442.html
    http://www.troublefreepool.com/what-...me-t11547.html
    Apr 2011
    25
    Thanks very much. I have read the pool school one, but not the others. Going there now to read. Thanks again!!
    Feb 2008
    Denton, TX
    5,061
    I would suggest that you run the filter at the time of day that you test and add chemicals. This allows for the ater to mix well which makes more accurate testing and also allows for chemical addtions to mix well in the water after you have added them. You shouldn't add chemicals or draw samples from the water with your pump off.
