New in the box. Product Description Stenner BDF5 single head variable output dosing pump for low pressure (25psi and below) applications. Stenner's adjustable 24-hour metering pump is built with a low rpm motor and a detachable pump head, universal to all Stenner pumps. The BDF pump has a fixed rpm motor which is activated by dip switches to inject scheduled daily doses of chemical. The pump can be programmed to activate hourly from 1 to 24 events per day. All Stenner metering pumps have a 3-point roller design in the pump head, which acts as a check valve to prevent back flow, siphoning, overdosing and loss of prime. •Variable Output (Ounces): 1.00 - 21.00 •RPM: 12 •Motor HP: 1/30 •6' power cord attached •Shipping Weight is 9 pounds •Dimensions are 10.1" x 6.1" x 5.3" •The Stenner BDF5 Pump uses a #5 Tube Included with every pump: •Instruction booklet •Pump comes standard with 1/4" clear tubing Options: •Stenner Pumps can be vertical or horizontal mounted Features: •Peristaltic Design - self-priming, can run dry without damage •Chemicals are metered without exposure to air •Pumps gaseous solutions •Accepts a variety of chemicals - refer to chemical compatibility guide •All housings manufactured from Lexan Polycarbonate Plastic •Manufactured in USA since 1957
If interested please email me at anthony.estamponi@ecolab.com
