Thread: What should calcium be?
    I've just replastered my 10,000 gallon, in-ground pool (great end of season deal) so its still open and I'm getting the water balanced. I've always used muriatic acid and often used bleach but am now going full BBB.
    Water temp is 60. TA is 60. Still working on the other variables. The one that has me perplexed is calcium. Our water supply calcium hardness is about 70 ppm and that's what I'm showing in the pool now.
    I've seen a variety of minimums listed--all over 200. But also saw a note, "Don't add calcium if your level is over 120."
    As I understand it, plaster contains calcium hydroxide. If I brush the pool, the plaster is still sloughing off. Until it hardens, I have no idea what I should aim for in terms of a calcium level now.
    Thanks!
    10,000 gallons IG, plaster, sand filter, BBB technique
    Pool built abt 1990; replastered in 2012
    Original pump; brushes replaced once
    South Central NJ
    3,192
    Re: What should calcium be?
    Most of all, with startup, what was used to plaster will dictate what should be used.
    Plain plaster, Diamond Brite, polished finishes, pebble finishes, all have slightly different targets and timings.
    What was used?
    Scott
    Owner of - PoolGuyNJ LLC
    Welcome to TFP!
    Don't adjust the CH level (or TA) during the first few weeks. As the plaster cures it will raise the PH, TA, and CH levels. If you raise CH now it could very easily end up being too high latter on.
    The pool is plain plaster.
    Feb 2008
    Denton, TX
    5,061
    Main thing for you to do right now is brush, filter, and keep your pH in check.
    Thanks for the tips. I'll follow them to the T.
    R.
