Thread: Seeping water
    Seeping water
    Well I got my pool kreet in and now I have two spots where I have a little seeping water from the walls.... it is less than a glass of water. The only problem is that the kreet won't set up.... NEED Help.... I thought about some quick set concrete a few hours before I put the liner in. It really isn't that much water to add additional drains and I am going to be fighting the temps soon.
    South Central NJ
    3,192
    Re: Seeping water
    You'll likely need more than you think.
    What were the soil conditions behind it? If there's clay and its wet and seeping, it won't stop but can be redirected though where it may go is anyones guess. It may go inward (best) up a little, down, laterally.
    Got a pic of the hole? Photobucket album, 4th option.
    Scott
    Owner of - PoolGuyNJ LLC
    Re: Seeping water
    Thanks Scott. I ended up putting some hydralic cement in the hole that set up in about 3-5 min. I then put my liner in and filled it up...... Thank God! I just needed it to last till I got the water above the spot and then I don't have to worrie a out where the water is going because it won't be going in my diving well.
