Results 1 to 8 of 8
Thread: To Much Salt...
    To Much Salt...
    My PB got filter and all up and running Friday. He added salt on Saturady morning. 600lbs into a 21,000 pool. Initial readings Saturday night only read 3200PPM on ProLogic panel. Taylor kit showed 3600PPM. Sunday morning and currenlty it reads 4400PPM and Taylor was 5000PPM.
    I am thinking this is to high and I should drain some water and fill?
    Ted
    Re: To Much Salt...
    600 pounds in 21,000 gallons will increase the salt level by 3400 ppm. What is the salt level of the fill water?
    Support the site
    Jun 2011
    Long Beach, CA
    2,790
    Re: To Much Salt...
    Is this a new build or have you had the same water for awhile? What I'm getting at, did you check your salt level before adding the salt? If the water had been in use for awhile it might of had a higher level of salt than you might think.
    Re: To Much Salt...
    This was new fill from truck, but city water (chlorinated) and about 1 week old. I have tested with both Taylor and looking at ProLogic panel.
    Re: To Much Salt...
    There is always some salt in the water to start with, though city water often has fairly low levels. Salt does take a little while to dissolve and mix completely (normally you give it 24 hours with the pump running to mix), so your description fits with there being about 1,200 ppm of salt in the water to start with.
    How important it is to get the salt level back down depends mostly on what brand/model of SWG you have. AutoPilot units don't mind the higher salt levels, but several other brands will refuse to function when the salt level is too high.
    Re: To Much Salt...
    I have Hawyard Pro Logic PL-PS-8 with a T-Cell-15. Manual says 3400PPM as the top range. Any other information?
    Re: To Much Salt...
    That unit will get a HIGH SALT error somewhere around 4000 ppm. The exact level is somewhat variable, depending on temperature along with other things. If you do get a high salt error you will need to lower the salt level.
    Re: To Much Salt...
    It is not in an alert mode for some reason, but reads 4400PPM. I called Hayward and they said not critical to occur ASAP, but should drain 10" or so of water and re-add.
