Thread: Testing Water In Winter Months
    Will someone please tell me if it is necessary to test my pool water in the winter. I leave my pool open in the winter. I normally test for cl and ph. I am using my TF100 kit this winter. It seems like the cl use would be near 0 when the water is near,or at freezing, keeping algae away. Any help is very much appreciated. THANKS
    20X40 IG,33,000 GAL,VINYL LINER,1 HP PUMP,HAYWARD SAND FILTER,CAMDEN,S.C.
    30,431
    Re: Testing Water In Winter Months
    My assumption is you don't intend to close the pool so, yes, in SC you would want to test and keep chlorine in it. Your pool water will seldom go below 40-45 in Camden.
    Mar 2007
    San Rafael, CA USA
    12,082
    You won't need to test as often since the chlorine loss rate will slow significantly. In the winter, I usually only need to test and add chlorine once every 1-2 weeks. Note that if your pool is uncovered, you may still have chlorine loss from sunlight, but in the winter with the lower angle of the sun this loss is lower as well. Just see how things go and set a schedule that makes sense for your pool.
    Thanks for the info duraleigh and chem geek. I'll test maybe once a week. I do leave my pool uncovered. It's nice to look at the pretty blue when all is so cold and gray.
