Thread: Polyquat or not? "Ammonium Chloride in solution"
    May 2011
    Dorset, UK
    33
    I'm in the process of closing the pool, and bought this to add after shocking.
    http://www.swimmingpoolchemicals.co.uk/ ... cts_id=848
    The MSDS is here
    http://www.swimmingpoolchemicals.co.uk/ ... aecide.pdf
    Just realised it is not Poly[oxyethylene(dimethyliminio)ethylene(dimethylimino)ethylene dichloride].
    Polyquat doesn't appear to be widely available in the UK. I have a tensioned mesh winter cover over the pool. Should I bother with an algaecide, or return it to the shop?
    Thanks!
    12ft x 24ft x 4ft inground vinyl, 32,000 litres, 3 phase 1.25hp Waterco pump on DIY VFD for cheap variable speed. 18kW Heat pump, Lacron sand filter, Solarmatt, 10kW Solar PV
    May 2011
    Dorset, UK
    33
    Re: Polyquat or not? "Ammonium Chloride in solution"
    Anyone with a view on whether to put this in the pool? Thanks!
    22,543
    I'd return it. If you've closed the pool per instructions found here you won't need it.
