Thread: Pentair IC-20 Power Light Red
    Aug 2011
    Frisco, TX
    26
    Bought a new house 2 weeks ago. Initial tests showed salt at only 1100 FC 0 CYA 50 Added 6 bags of salt to get to 3100. Then noticed all of the lights were green on the cell except the Power light which was Red-service. Any ideas of troubleshooting.
    Pool is 5 years old no idea on how old the cell is.
    My thought now with the initial low salt was the cell has been dead for a while and the previous owner just used clorine pucks.
    14,000 Pebble Sheen Salt Water Pool All Pentair Equipment/ Cartridge Filter, 400K BTU Heated.
    Re: Pentair IC-20 Power Light Red
    A red power LED almost invariably means the cell needs to be replaced.
    South Central NJ
    3,192
    Red means over 10000 hours on the cell and it's time to put a new replacement cell in.
    Scott
    Owner of - PoolGuyNJ LLC
    Quote Originally Posted by PoolGuyNJ
    My understanding is that 10,000 hours on the cell turns the "Life" LED red. When the "Pwr" LED is red it means that it failed the self test.
    Aug 2011
    Frisco, TX
    26
    Thanks for the responses. So all I need to do is order the replacement cell? Or could something else be causing the issue
    May 2011
    36
    If it is a 2.0 cell then replace the flow switch. The flow switch also has the temp sensor built in to it and chances are that has gone out. The normally still work but they have no clue what the salt level is.
