i closed up my pool in sept and i did not use antifreeze in the lines i just blew out the lines and added plugs... should i fill them up with anti-freeze now? i'm in orillia, ontario, canada and sometimes we see temps down to -30 c..
Would it be stupid not to put the antifreeze in?
How do you take it out in the spring?
Also, there's quite a bit of water on top of the cover & leaves. Should i be cleaning the winter cover off often?
Thanks!
Thanks!
