Thread: Pool Heater - What is normal operation supposed to look like
    Hey guys,
    I'm back with another question, this time my pool heater! It's getting cooler and we're starting to think about heating the pool and using the spa more often.
    When I turn on the spa, the jets blow hot water, then it cools off, then hot water again and this cycle continues. Is this normal operation for a pool heater? The system is currently set for 104 degrees.
    Thanks guys, as always your help is appreciated!
    -Tom Woolley
    -Tom
    17,000 gal plaster with spa. Pentair Clean & Clear cartridge filters. Jandy systems with Aqualink RS and Polaris 360.
    Pool Store free since May 2011!
    Jun 2011
    Long Beach, CA
    2,790
    Re: Pool Heater - What is normal operation supposed to look
    When I run my spa the heater warms the water to the set temperature and then shuts down. The water circulating in the spa starts to cool and once the water gets about 2 degrees below the thermastat the heater kicks in again. Right now with the weather we have it takes about 20 minutes for the water to cool down and then the heater runs for 3-4 minutes.
    Okay, something is causing my heater to cycle on and off for 1-2 minute intervals. I was under the impression that was normal.
    -Tom
    How many gallons is the spa and what size is the heater?
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    If you have a lot of aeration, you can cool the water off fast And the heater probably cycles off when it hits target and back on when it drops 3 degrees or so. It could very well be working exactly the way it's supposed to.
    I don't turn on the blower nor the booster pump when I use the spa. And I stick an old yogurt lid over the air intake on the spa jet piping; I'm not heating the water up so I can cool it off right away! It heats faster and stays hot longer with fewer air bubbles in the return stream. By the way, when the pump turns off, the lid is no longer held on by the vacuum created in the venturi, and falls off.
    No it cycles before the water has even reached close to target temperature. I guess I'm going to have to call the home warranty company again
    -Tom
