Thread: Ambient temperature sensor
    Nov 2010
    Calera, Al
    271
    I am considering adding an ambient temperature sensor on my pool equipment. My question is this a diy job and if so how difficult would it be? I am a diy type of guy and very handy, but have not had experience with this type of device. Is it feasable for me to install the sensor, if not what type of professional should I contact to do the work and about how much would this install cost?
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Re: Ambient temperature sensor
    What do you want this temperature sensor to do? If you already have an automation system, they usually come with a temperature sensor, and if they don't it is easy to attach one. But if you don't already have an automation system, you need to specify exactly what you want the sensor to do and figure out how it will integrate with your existing equipment. One common setup would be replacing a mechanical timer with a new timer that includes freeze protection. That can cost around $100 and is fairly easy if you have any experience with AC wiring.
    Nov 2010
    Calera, Al
    271
    I have a dual intermatic timer no automation. what I would like it to do is act as a freeze protection and just kick on the system once the temps drop below mid 30s.
    22,553
    If your timer doesn't have freeze protection then you're either going to need a new timer that has freeze protection or a temperature switch calable of switching the pump on and off. A switch is probably just as costly as a new timer.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
