Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: Leaking at the motor/housing
    Oct 2011
    Charlotte, NC
    120
    So after 2 years of trouble free running, my Hayward superpump developed a slow leak and I figured it was the housing gasket or the ceramic seal. After some internet research and talking to Leslies, I figured it was the seal so I replaced it myself following an instructional video. Still leaking.
    So I take the motor to Leslies and they replace the seal, I bring it home, still leaking.
    I return to Leslies, show them the gaskets. They say they look ok but we replace the O ring impeller gasket and housing gasket. These are aftermarket gaskets and the housing gasket looks different from the OEM gasket. I try them anyway, still leaks.
    Next I order a Hayward OEM housing gasket. Still leaks. I cannot find a crack in the housing and it only leaks when running. What is going on. Leslies has waved the white flag and are stumped as am I. Experts?
    8000 gallon outdoor inground vinyl. Sand filter, Hayward 1HP.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Re: Leaking at the motor/housing
    Could you post a picture of the leak?
    Love TFP? Become a
    TFP Supporter!
    Oct 2011
    Charlotte, NC
    120
    I Can but it's been raining here for 2 days and probably tomorrow AM as well so I need to wait for it to dry up out there. I will tell you, that from what I've read, it is consistant with either a ceramic seal leak or a housing gasket leak. It is just wet stain about 8" in diameter centered where the motor mounts to the housing.
    Aug 2007
    near the swamp
    806
    inspect the seal plate for cracks, and the impeller shaft if it's the old plastic type
    Oct 2011
    Charlotte, NC
    120
    The impeller shaft is not plastic and is fine. Can you help me out with the seal plate? I'm assuming it's somewhere near the ceramic seal but is it underneath the seal or where the seal is mounted?
    Aug 2007
    near the swamp
    806
    yes where it is mounted, pull it off and check the back for cracks
    Oct 2011
    Charlotte, NC
    120
    Ok, I will check that out. Thank you. Is that common?
    Oct 2011
    Charlotte, NC
    120
    So here is a pictire of the leak. It appears to be coming from where the motor mounts, which made me think it was the housing gasket.
    Oct 2011
    Charlotte, NC
    120
    So the seal plate looks fine and I still have the leak. I am completely confused and frustrated. Anyone have any thoughts on what could be causing this leak?
    South Central NJ
    3,192
    When Leslie's changed the gaskets, did they use a Super Pro Go-Kit?
    I suspect the impeller shaft is cracked. Remove the impeller and take off the seal. Blow air on it to dry it out and look for a hairline crack its the shaft.
    Remove the other seal from the seal plate. Again, check for hair line cracks.
    Use a bright light and magnifying glass.
    Scott
    Owner of - PoolGuyNJ LLC
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Could it be leaking from the top pipe fitting? In the picture you posted there seems to be a line of where water is dripping down, it's just aft of Hayward Manufacturing tag.
    Oct 2011
    Charlotte, NC
    120
    Quote Originally Posted by bobodaclown
    No, it's definitely coming from underneath somewhere.
    Oct 2011
    Charlotte, NC
    120
    Quote Originally Posted by PoolGuyNJ
    Scott
    The only Leslies gasket I used was the O-ring gasket from a kit of 3. I ordered a housing gasket from Hayward after the the Leslies housing gasket did stop the leak.
    If there is a crack do I need to just buy a new motor? Is this common?
    I'm confused as to why, after changing the seal both times, it ran for a day or so without leaking then started dripping again.
    22,553
    Sometimes a crack in the seal plate is very hard to see when it's not under pressure. Check it again closely.
    Oct 2011
    Charlotte, NC
    120
    Ok, I will. Are seal plate cracks common? Will I need a new motor if it is cracked? Thank you all for your advice.
    22,553
    They're not all that common but it does happen. If it is cracked all you'll need is a new seal plate.
    Oct 2011
    Charlotte, NC
    120
    Ok, so I removed the seal plate and the back of it is soaked. It would seem to me that if there is water behind the seal plate when removed that either the seal is bad or there is a crack in the plate somewhere. Is that a correct conclusion?
    I am am fairly confident that the seal is good since I replaced at twice in the past month so am I looking at a cracked plate even if I cannot find one?
    22,553
    The cracks can be very hard to see. They can be behind a boss or rib. I'd take it to a motor shop or pool place and let them look at it.
    Oct 2011
    Charlotte, NC
    120
    I'm taking it to Leslies tomorrow. I can't find a crack anywhere but there was a bunch of water behind the seal plate so it's getting in somehow. I guess I can just buy new seal plate and see if it stops the problem.
  20. Back To Top    #20
    22,553
    I wouldn't just buy one until several people have looked at it and inspected the seal area and o-rings/gaskets and sealing surfaces well.
