Thread: Pool timer stopped working
    My pool timer stopped working. It stopped turning. It is one of those 24hr round yellow timers. From what I've read online I think it is an Intermatic although I don't see the name on it anywhere. It sounds like it is still working. I can hear it buzzing but none of the gears are moving. I'm guessing the motor has burned out...I guess.
    Here are my questions...
    I'm running a 1.5hp pump. I am trying to figure out what the voltage is without a meter. Any idea how to do that just by looking at the timer and pump?
    Should I replace the whole inside or just the motor?
    Where can I get these things? Home depot or lowes or only pool stores?
    Any other insite would be greatly appreciated as I am not that technically savvy.
    Tried to attach a picture but too large. It looks just like this. Except it's a metal cover not plastic.
    http://www.amazon.com/Intermatic-T104R3 ... 25&sr=8-15
    Weston
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    I got mine at lowes,then had to hit up Locke supply for extra timer tabs. They may have the Timer as well.
    27000 gal 18x36 rectangle In-Ground built in 1978
    Vinyl liner, 3/4hp Hayward Super pump, single speed 3450rpm
    SWG: Hayward Aquarite AQR15
    Sand Filter: 300 pound sta-rite T-240BP-1, 3.14 sqft surface area
    K-2006 Test kit
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,945
    Re: Pool timer stopped working
    It's a pretty easy fix. HD and Lowes should both have the timer and they aren't very expensive.
    chiefwej
    22,553
    To figure out what the voltage is look at the pump motor. If you can read the data plate, you can find the voltage. If it lists dual voltage then look at your breaker box and see if the pump uses a single or a double pole breaker to power the unit. If it's single it's 120 volts, if it's a double pole, it 240 volts.
    Jun 2007
    New Jersey
    653
    If you just replace the timer motor, you just need to power down. Remove the small white wires and mark which screws they were on. Pull the mechanism forward (there is a little spring clip on the side to free it) and remove the motor from the back. Take the motor to your local Intermatic dealer (find it here:http://38.127.130.174/listing/guide/...al-distributor Probably 75% of local electrical supply houses are Intermatic dealers. The counter guy will match it and you put it back just where it was with the two white wires on the same screws. You never really need to worry about what voltage your pump is. Just make sure all power to the timer is off.
    They put the exact same timer into metal and plastic boxes. Swapping motors is easier and cheaper than swapping timers, but you need a dealer to get the motor. There are 12,000 plus of them.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
