Results 1 to 8 of 8
Thread: $5300 for solar heating for my pool - is this a good deal?
    I got a bid from Son Energy for 450 sq ft of solar heating panels for my roof to heat my pool. Is this a good deal? Does anyone know about solar heating?
    30k gallon, 793 sq ft, 50x21 infinity edge pool, 8x8spa, shotcrete plaster, Pentair intelliflo vs3050 pumps (2x), Pentair 2hp spa jet pump (1x), Pentair EZ Touch 8 indoor & outdoor, Pentair IS4 spa controller, Pentair Clean&Clear Plus 420, Pentair Intellichlor SWG
    Re: $5300 for solar heating for my pool - is this a good dea
    You might want to get several estimates to compare. Most manufacturers will have a "Find a Dealer" app on their site.
    http://www.heliocol.com/find/index.php
    How high will the panels be above the pool water?
    Support the site
    Feb 2011
    Petaluma, Ca
    665
    I recently put in 6ea 4' x 12' helicol panels, for just the panels, mtg, and plumbing was $3500. The sys was stubbed for solar at the equip pad and the automation was already in place.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    kenandshari's Avatar
    Aug 2010
    Savannah, GA
    134
    I did my own solar install last April and installed 5 Aquasol panels 4' x 12'. It took a week of evenings after work and a Saturday morning to do it all myself. I learned all I needed to know from the manual, TFP posts, and a couple of other web sites with good cartoon explanations. It really was not all that difficult and I literally did it all myself. We already use a Pentair Easytouch control system so automation was built in and ready to go from the start. We spent just under $2000 on the entire project including PVC, fittings, & valve actuator. It works great and we were swimming in 83 degree water this past weekend (we also use a solar cover in fall & spring). Really, it depends on what you want. Either way, I'd get several estimates and compare them to find the best solution for your situation.
    Ken & Shari
    Savannah, GA
    16' x 40' freeform fiberglass inground (Pacific model, mfg by Tallman Pools), 23k gal, 2" plumbing throughout, Intellichlor IC-40, Easy Touch controller, Intelliflow VS 3050 pump, Pentair Clean & Clear Plus Quad Cartridge filter. 4 Jandy deck jets (3/4" plumbing), Fiberstars color changing lighting, SR Smith salt friendly diving system, Interfab Wild Ride slide, Aquasol Solar Heat (5 panels 4'x12' DIY install automated with ET) RIP Nitro Wall Climber Mar 2011-Aug 2012, Nitro is survived by a Polaris 360.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,054
    That may be inline. I paid $3150 for 192 sq ft, Aquatherm panels and believe me it is worth it. We keep the pool at 88-92 degrees and we love it. Look at out solar install in the sig bar
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Every TIME I look at your pool, I want it and the view!!!
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    MattM's Avatar
    Jul 2011
    San Diego, CA
    299
    Son Energy offers a $500 rebate if referred by angies list.
    They seem to do an OK job.
    We had 550 sq ft of heliocool installed by Son Energy for a new pool for ~$6,700.
    24K gallon inground gunite/pebble sheen pool, 34'x16' 4-7.5ft deep, 750sq ft solar, pentair ultratemp, intelliflow vs+, ic60, intellichem w/ acid pump, quad de 100, intellibright 5g, intellitouch i5-3s with Screenlogic2, 3" primary piping - 2.5" at equip pad, auto switched deep heating and main returns, automatic safety cover w/ electronic lock and embedded recessed undertrack, sealed stamped concrete deck, dolphin deluxe 5, started up December 2011.
    Quote Originally Posted by MattM
    Hi Matt, do you have another company you recommend? Thanks
