Thread: Intelliflo Weather Resistance??
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    I've read in a few threads here about some assertions about the Intelliflo series having issues with Rain intrusion.
    That can't be true, can it?
    I can't imagine something that should be more weather proof than an outside pump.
    Anybody have any experience with this?
    14x30 PebbleTec(Caribbean Blue) 12,000 Gals BORAX
    Pentair IntelliFlo <<>> Pentair FNS Plus DE
    Pentair 5G Intellibrite w/Intellibrite Controller
    ROME Solarium 125 Heat Pump
    Kreepy Krauly Classic <<>> Pentair 320 Feeder
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    Re: Intelliflo Weather Resistance??
    Below is from Pentair VS 3050 manual page 18
    3. Protect against moisture:
    • Protect from splashing pool water.
    • Protect from the weather.
    • Protect from lawn sprinklers.
    • If a motor has become wet - let it dry before operating. Do not allow the pump to operate if it has been
    flooded.
    • If a motor has been damaged by water it voids the motor warranty.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    South Central NJ
    3,192
    This is solely because the electrical connections are not water proof. They should be weather tight but that doesn't make it like a Timex G-Shock divers watch. Any other pump will have that warning also.
    If you used electrical connections designed to be submerged, the pump would run fine fully submerged. This actually happened during development when the Santa Ana winds blew it in on a Friday and they found it on Monday, still running.
    Scott
    Owner of - PoolGuyNJ LLC
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    Quote Originally Posted by PoolGuyNJ
    Scott
    So basically if it is protected against shorts from water intrusion, it's OK?
    The IntelliFlo has a sealed enclosure, which most pumps do not have. So it is safer outside than most pumps (which none the less do alright). As PoolGuyNJ said, that doesn't mean it is perfectly water proof, but it is quite water resistant and safer from things like sprinklers splashing the pump than most other pumps would be.
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    Thanx! That's kinda what I was hoping for.
