Thread: Dark plaster, milky swirls, when can I brush?
    Jul 2011
    Las Vegas, Nevada
    139
    We have brand new dark gray plaster and some areas are a very light gray, nearly white. I know darker colors mottle easily and we really like the mottled look, but in the spa it is just really bad. Like it wasn't brushed well enough in the first couple days. Same thing around some of the edges of the steps. Tonight I took a small piece of sandpaper and rubbed one of the white spots and it took it right off. I really don't want to sand the whole pool, so I guess I am wondering what else I can do to remove the milky areas. I was told that I can't use a wire brush one it.
    Jay...12,500 gallon freeform pool and attached spa w/ Bullfrog Oscillator & ClusterSpray Jetpaks
    Jandy 2hp VS pump(main), Jandy 2hp Stealth pump(Jetpaks), Jandy 1hp Stealth pump(water features) Jandy CL-580 filter, Jandy Watercolors LED lighting, Jandy Aqualink RS8(revision MM) w/Aquapalm, Autelis Controller, Onetouch controller, Jandy Aquapure 1400 SWG, Jandy LXi 400k heater, Paramount PV3 6 zone infloor cleaning system
    Feb 2008
    Denton, TX
    5,061
    Re: Dark plaster, milky swirls, when can I brush?
    Did you do the plaster yourself or did you contract it out? If you contracted it out, talk to your sub about it before sanding anything down.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Some test results may help; a thin white film sounds like it could be calcium scale forming!
