Results 1 to 8 of 8
Thread: Test tube measures consistent?
    kjdiver's Avatar
    Jan 2009
    Virginia
    69
    I have bought several tests, replacement tests, and obviously the TFP test kit...all through TFP. I now have 5 test tubes with ml measurements on the side. Of the 5, 3 are equal measurements when I fill it with 25ml. The 25ml poured into the other 2 tubes are closer to 30ml.
    1. Am I crazy?
    2. What tubes do I use??? How screwed up have my tests been for the last 2 years?
    3. Shouldn't all the test tubes be labeled accurately?
    3. Kinda feeling crazy!
    Thanks!
    25k old school pool - new plaster and tile Dec 2017 -> Jandy FHPM1.5-2 -> Tagelus 60 -> CompuPool CPSC48 -> Raypak Heater -> RIP: Polaris 380 w/ booster pump - New Cleaner: S300i Mar 2018 -> TF-100 with many refills
    Feb 2008
    Denton, TX
    5,061
    Re: Test tube measures consistent?
    See if you can get your hands on a syringe. A 10 ml syringe would be useful in helping you determine which tube's measurements are closest to being correct.
    22,542
    I use a 10ml syringe and never worry about the markings on the vials. I'd love to get a 25 or 30 ml syringe but haven't found one so far.
    Montreal Canada
    326
    Class-A volumetric flasks are available in 25 mL sizes however you can't really use them for titrations and such, but they contain precisely 25 mL.
    You have different types of labware, "To Dispense" and "To Contain". (Flasks are "To Contain" or "To Dispense", empty one in a Taylor 9198 and observe that the 9198 is bang on).
    It also helps to view the meniscus behind a white card inscribed with a dark line.
    Best is to weigh the water, 25 mL weighs 25 grams.
    Jul 2011
    Central Califorina
    208
    I'm in the medical field and have access to 60 ml blunt tip syringes. These are great because I take a sample from the pool and can get a PH and FC test with it. I use a 20 ml syringe for the CYA test. It would be great if these syringes could be included in the TF-100 to help people get more accurate results.
    3500 gallon 14x42 Intex Ultra Frame
    1/2 HP Intex 1600 sand filter/pump - Intex SWCG
    Two 4x20 Fafco solar panels.
    Taylor K-2006
    Marquis spirit hot tub - Grill Dome ceramic grill/smoker
    http://www.allegromedical.com/syringes- ... 91862.html
    $17.81 for a box of 40, or $1.00 each.
    Support the site
    22,542
    Yeah but with shipping of $8.95 that's 10 bucks for one. And that's all I need. Maybe what I should have said, was I haven't found one at a reasonable enough price to actually buy one.
    I would think that a local medical supply place would have the 30 ml available.
    Support the site
