Results 1 to 8 of 8
Thread: Rough Estimates for Stenner System
    I currently use an automated Tab Chlorine System. After spending the last few days reading everything I can find on this board (which is a lot) I am having difficulty making an educated estimate for my Stenner needs. I am trying to maximize ease of use, not necessarily the most expensive route, but not really money adverse either.
    I want to buy a system, Install it, and then tinker with flow-rates and such without going through an intermediate step of manually buying and dosing with liquid chlorine ... and the peak season is over anyway, so I still want to get a system in place now that can scale up next year.
    So my questions:
    1) My pool holds 30,000 gallons of water. How much chlorine will I be using on average during the peak months and what is the most I can store outside considering chlorine breaks down with time and temperature.
    I live in Austin Texas :Austin summers are usually hot and humid, with average July and August highs in the mid-90s °F (34–36 °C). Highs exceed 90 °F (32.2 °C) on 109 days per year, and 100 °F (37.8 °C) on 12. This last year we had 27 consecutive days with 100-degree highs.
    I know that their are all kinds of variables -- but is it reasonable to get a 30gal container, or is that clearly too big. It seems that most people are using 15 gallon containers ... is this a kind-of "magic" point between ease of use and chlorine disintegration?
    1a) How long will chlorine be viable in this heat? (Assuming it is UV protected). I may use regular 6%, or may have access to 12.5%.
    2) Which pump? It seems to me that I can do everything with the Stenner45MP1 Single Head Fixed Output Low Pressure Pump, for 10$ more I can get the high pressure -- is it safe to assume that my pool output is under 25psi? Or is 10$ good insurance?
    Thanks in advance... I will certainly have more questions later about how to automate this with my existing electronics, but I want to get this part working first.
    Austin, Texas
    30,000 gallon Gunite/Pebble
    Pentair Clean and Clear Plus CCP 520 Cartridge 150GPM
    Pentair Whisperflo WF-28 2HP Pump
    Delzone Eclipse 4 Ozone Generator
    Re: Rough Estimates for Stenner System
    In Texas guessing at worst case you could be using 1.5-2 gallons a day of 6%, maybe even 2-3 gallons if you are having a pool party as well as extreme heat. In more typical conditions, most of the season just not the peak of summer, I suspect you will be under 1 gallon a day. Of course, if you are shocking the pool you can go way over that, but that can be added manually. You have some control over this. By raising the CYA level a little you can cut the chlorine consumption somewhat, which is often worth doing in those kinds of conditions.
    Even with 6% at 2 gallons a day you will get a week out of a 15 gallon tank. If you raise the CYA level a little you should easily be able to get two weeks from 15 gallons. The 30 gallon tank doesn't hurt anything, but it is unlikely to be needed.
    With 6% chlorine you are fine for two or three weeks. It will lose some strength at 100 degrees, but it won't be a big deal. With 12.5% you will have much more noticeable loses due to the heat and I would try to hold things to a week per fill or put the tank somewhere cooler. You can actually go longer, I am being conservative. But if you do go longer you may end up needing to adjust the feed rate a little higher to account of loss of strength towards the end of the tank.
    What does your filter pressure run? Most pools will be under 25 psi, but with a 2 HP pump you might be going over that, depending on how your plumbing was done.
    First, thanks for the reply... this board is very cool ... I hope to be able to support others too!
    I don't know how to determine filter pressure ... I guess I need to look into that ...
    I guess if I dig a whole, the 12% would be ok for 2+ weeks which seems like a nice workable schedule for me...
    So that will be the plan for now ... I will get the 15 gallon and plan to bury it up to the pump...
    Thanks again ...
    Austin, Texas
    Most filters have a pressure gauge right on the filter, used to determine when the filter needs backwashing/cleaning.
    22,468
    Just adding my thoughts.
    Spend the extra to get the adjustable output pump.
    I agree with Jason that you'll need 1½ to 2 gallons per day.
    If you want to run your main pump 8 hours a day, you'll need an injection pump that's capable of delivering at least 6 gpd. The 45M2 is 10gpd which in the closest to your needs.
    If you run your main pump 24 hours a day then you can get by with the 45M1 pump. Though I'd probably go with a slightly bigger pump any way.
    I recommend getting the high pressure pump. It includes a check valve at the injection point.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    ChiknNutz's Avatar
    Jul 2010
    Arlington, WA
    145
    Take a look at my last post in this thread. I uploaded a spreadhsheet that you may find useful. I have a 36K gallon pool. Close in size, but different geography. See if it helps. post320058.html#p320058
    Chris A.
    20x40 36k gal IG vinyl pool w/diving board & slide | 1.25HP Pentair Challenger motor & pump | 30" Triton TR100 sand filter | Pentair SM-20-3 multiport | Stenner 45MHP2 Peristaltic Pump & 13 gallon carboy (BBB) | Hayward CL200 Tablet Chlorinator (used on pool startup) | TF-100 | 2003 Sundance 850 Altamar hot tub
    Dec 2010
    San Diego, CA
    1,137
    X2 on the adjustable pump for the flexibility, and you can always just leave it at 10 and treat it like a fixed rate pump.
    I'd also go with the 100psi version too - it comes with a check valve at the injection point but I'm not sure if the 25 psi ones do (someone correct me if I'm wrong) - it'll give you an extra measure of safety.
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Feb 2011
    Central Texas
    187
    Curious, did you ever install the system? I missed this thread, but I put one in last year and it was a sure fire way to dose chlorine at the right amount, every day. I have about 23K gallons and used around one gallon a day last summer. I had my CYA at around 45.
    IG 23K Gal, Quad DE 80, PebbleSheen, Intelliflo VS+SVRS, MT 400 NG, Stenner Pump
