Results 1 to 9 of 9
Thread: Aquarite problem
    Sep 2011
    Miami Beach, FL
    125
    Aquarite problem
    So I was getting low salt readings and flashing check cell and check salt LED's.
    I know my salt was actually a little high by test kit assay.
    Cell is clean.
    So I decided it was symptomatic of my 3-4 year cell dying and bought a new one.
    NO change in readings or LED's
    All my voltages/amps are in spec too....
    Thoughts?
    32000 gallon, inground, fiberglass, Aqua-Rite SWG, Pentair 420 sqft cartridge filter (Installed-ya baby), Hayward Super II pump 1.5 hp, 144k BTU heat pump, Dolphin Dx5 Plus, and a good test kit from Duraleigh!
    South Central NJ
    3,192
    Re: Aquarite problem
    Water temp?
    Scott
    Owner of - PoolGuyNJ LLC
    Cold water, say below 60 degrees, can cause the salt level to read lower than actual.
    Sep 2011
    Miami Beach, FL
    125
    Miami Beach...water is still 76
    Sep 2011
    Miami Beach, FL
    125
    Any suggestions for a next step figuring this out?
    Thanks
    South Central NJ
    3,192
    Open the panel and look for anything burnt. Check the wires for burn marks and corrosion.
    Scott
    Sep 2011
    Miami Beach, FL
    125
    OK, been awhile but...
    Unit still reading low 2100 and not generating despite multiple tests showing 3200-3400 salt.
    pool temp is 80 degrees.
    New cell.
    No burnt parts on board, fuse is good.
    I replaced the black disc anyway just in case.
    I guess I will by a new main board unless someone has an idea?
    thanks
    Aug 2007
    near the swamp
    806
    You didn't see any burn marks on or around the varistor like this(actually cracked)?
    Sep 2011
    Miami Beach, FL
    125
    No, I did not. but I replaced it anyway.
    No change in the symptom of low salt reading
