Results 1 to 16 of 16
Thread: Comparing Chlorine Costs
    I was doing the same calculations over and over to determine the cheapest cost of bleach for my pool -- so I created a spreadsheet that assists with this and thought I would share it.
    If you find a source for bleach (i.e. Walmart or Albertsons) and want to know if it is cheaper that another source -- which happens to be at a different dilution or quantity, you can do that easily with this sheet.
    Just enter the concentration (6,10, 12.5%), the quantity (Gallons or Oz), and the price. The sheet will return for you the price you would pay for the same amount of chlorine in various volumes and concentrations.
    The sheet is locked (so that you can only enter into the cells that are input and not into formulas) but it is not password protected, so if you want to fiddle with it, you may just unlock it.
    edit:
    Doesn't seem that I can attach it, so I put it up on a webserver here:
    http://www.david-traub.com/chlorineCalc.xlsx
    Austin, Texas
    30,000 gallon Gunite/Pebble
    Pentair Clean and Clear Plus CCP 520 Cartridge 150GPM
    Pentair Whisperflo WF-28 2HP Pump
    Delzone Eclipse 4 Ozone Generator
    Jul 2010
    Philly
    332
    Re: Comparing Chlorine Costs
    Nicely done. I like how the prices are extrapolated to reflect the corresponding cost in different concentrations. Makes it easy to compare my cheapest source of household bleach against the pool stores' 12.5% price.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
    May 2011
    Coral Springs, FL (near Ft. Lauderdale)
    93
    Great spreadsheet. Thanks! Makes it handy to compare prices across concentrations. I added a store column to keep track of where I found each item and keep the spreadsheet on my BlackBerry.
    15x30 inground concrete pool w/spa and spillover, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter and Hayward Navigator V-Flex
    Jandy AquaPure 1400, Laars LX400 propane heater w/120 gal above-ground tank
    Jandy VS FloPro 2.7 HP Pump VSFHP270JEP; FlowVis FV-C Flow Meter
    Jandy iAquaLink and OneTouch controller w/PDA remotes; JVA for draining pool
    Jun 2011
    Apple Valley, MN
    19
    Don't forget about the Bleach Cost Comparison that someone has shared out on Google Docs. Any that you see from the Minneapolis MN area are probably from me:
    https://docs.google.com/spreadsheet/ccc ... zVHemhfdHc
    25000, IG, Vinyl with Hayward S-240 series Sand Filter, Emerson 1081 Pool Motor, Hayward H250 Heater.
    May 2011
    93
    Thanks for the link, but the owner has apparently not made the document public. I had to request access. They should consider making it publicly accessible.
    Montreal Canada
    326
    Because all measurements (from a test kit) and additions of chlorine are done using ppm as a unit of measurement, the spreadsheet should reflect the cost per ppm for whatever source of chlorine.
    My own spreadsheet has a columns where you enter product volume, concentration, specific density (if bleach), and price. It then calculates the cost per ppm for a 10,000 liter pool. That number can then be scaled for whatever volume pool.
    I know that a 30 ppm shock for my pool costs $1.44 using cal-hypo.
    May 2011
    93
    Quote Originally Posted by CaOCl2
    Sounds like a great idea!
    Can you please post a link to your spreadsheet?
    Thanks!
    Thanks for the great spreadsheet. I have been trying to figure out if chlorine from the pool store or bleach was cheaper an clearly chlorine from the pool store is cheaper in my area but without this i never would have figured it out. Thanks!!!!
    Cleveland, Ohio
    IG 36,000 gallons. Vinyl Liner, Hayward ProGrid 3620 DE Filter, Hayward Super Pump, Hayward Gas Heater
    It appears that the spreadsheet is gone. Does anyone else have it and can post it here or email it to me.
    JimB
    on the Northcoast of the U.S.A.
    24ft AG-13,500 gal-Hayward S-166T high rate sand filter-pump is SplashPak Hp 1spl (whatever that means)-TF100 test kit
    Jun 2012
    South Louisiana
    24
    Just saw on the Clorox website that their bleach will come concentrated in smaller bottles in August! IDK what concentration, but I'm all for smaller bottles to lug!!!
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by JimB
    Is this the spreadsheet you're looking for? Not my creation, just reposting.
    Attached Files Attached Files
    Looks it may be. Haven't tried it yet.
    Thank you for posting.
    JimB
    Apr 2012
    Northwest Ohio
    8
    Is EQArtimus willing to post their spreadsheet again? Thank you!
    2004, 22.5K Gal., 36x18, IG, Vinyl, TF100 test kit, 1HP Waterways Pump, 20 GPM/FT Hayward Sand Filter, 200 BTU Hayward Gas Heater, Dolphin Supreme M4 Robot, Powered Cover
    Quote Originally Posted by Pop_s
    I wish he would. I would love a spreadsheet that calculated the cost per oz....
    29,000 gallon irregularly shaped in ground pool. Plaster. DE Filter. 1 hp pump. Pool approximately 10 years old. Polaris 380 robotic cleaner. Middletown, Delaware.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Is this the one you're looking for https://dl.dropboxusercontent.com/u/...ch%20Chart.xls?
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Montreal Canada
    326
    For any Canadians reading this, Costco has "HTH Max 70" cal-hypo, 70% concentration, a 22,7 kg bucket for 69,99CDN$, it's a great deal, works out to 0,0440$ per ppm (for 10 000 liters)
