Results 1 to 8 of 8
Thread: Best leak detection device
    Oct 2011
    15
    I'm in the pool business. My most frequent service call is for leaks. I deal primarily with unground vinyl liner pools and a few plaster pools. Is there any certain device that helps you pin point non pressurized still pool leaks rather than diving in?? I don't care to pay as long as the leak is detected.
    Thanks
    Re: Best leak detection device
    There are a couple of choices, for example this one, that work with vinyl liner pools. I have never tried any of them, but I have heard good reports. Unfortunately, the approach they use doesn't work at all with plaster.
    South Central NJ
    3,192
    The leak detector Jason pointed only works on liner pools. It will not tell you if a light niche conduit is leaking, nor will it check drain, step gaskets, and wall fittings. That is because there is metal there and the micro currents it senses are drawn to the steel. When it passes over a split seam in a liner or other hole, it finds it every time. I duct tape a crayon to circle the area needing the patch.
    You still need to jump in with a dye pen to find gasket and light niche leaks.
    Scott
    Owner of - PoolGuyNJ LLC
    X-PertPool's Avatar
    Exeter, PA
    1,385
    If you do buy that device learn to take care of it. Kinda how someone takes care of a rifle. You can't just load it with batteries and forget it.
    You need steel wool to clean the brass on the probe and the float when they tarnish. You need to keep lots of extra AA batteries on hand and 9 volts (I believe it's 16 AA and 2 9volt)
    Change the batteries once a season ( or more depending on use), take all batteries out in the off season.
    I was also advised to make a mixture of lithium grease and graphite (like you use on door knobs) and place that goop inside on the contacts near the adjustment dials.
    You'll need to learn how to find a good ground (by using ladder cups or a metal spike in the ground)
    When you are done leak finding the equipment is usually wet and is stored with the electronics, you might want to invest into a desiccant (one you can reactivate in the oven) to keep in the case.
    The leak finder works in vinyl and fiberglass pools (although I never used it in fiberglass)
    Light shields are a descent investment (not sure if they still sell those, they were big plastic shields that would go over the light to remove the pool light's grounding signal)
    Take care of your device; you'd be surprised how many times I get called out because no one else in the area had a working unit.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Oct 2011
    15
    How much are they? Do you buy them direct from the co. Also will they locate a leaky aqua genie?
    South Central NJ
    3,192
    They sell direct and through distribution.
    Won't do anything for skimmers. The screws in the face plates interfere. See my earlier reply.
    Scott
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Anderson has a booth at the Atlantic City pool and spa show. There is usually show pricing and you can see all of the stuff they have for finding leaks in various areas. Also they usually have a tiny pool setup to show you how the device works.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    My PB used on of those devices in my pool and it work great! I ended up with 5 leaks that needed patched. Most toenail holes from people climbing up the side wall instead of using the steps......no more climbing my walls. New rule in grammy's pool!
    18,000 gal, 18x32 IGP, vinyl liner, 3 to 5.5ft depth. One inlet/skimmer (Aqua Genie), one main drain. Hayward Pro Series Sand Filter w/filtration rate of 20 GPM/FT, Two-Speed Pentair Whisperflo 1 HP pump, Natural Gas Hayward H200 pool heater, Aquabot T2 (200 Series) Robotic Pool Cleaner (my best friend), Automatic Electric Pool Cover (2nd best friend).
