Thread: Just how loud is an Intellipro?
    Oct 2011
    San Antonio
    16
    We are about to make our choice of PB and design. One guy uses a Hayward and the other Pentair equipment. In my youth, we had a pool- nothing like what is around today- but the pump, when new or old was a screamer- It was loud and if you were swimming you wanted it off because of the noise. How loud are the two above pumps? How far away do most of you place them? I checked my neighbors but his is quite some distance from the spa. Do I try to place the spa and pool pumps as far away as possible (costlier) or are they quiet ?
    Mark ---San Antonio
    Re: Just how loud is an Intellipro?
    An IntelliPro, and essentially all variable speed pumps, is very quiet when running on a fairly low speed, which is where you will tend to want to run it most of the time on most pools. However, they can be fairly noisy, though certainly not to the extent you describe, when run on full speed. While you are in the spa and have the jets running, you will want to run it on a fairly high speed, so the spa jets feel right.Still, in most spas, the bubbles make more noise than the pump, though that varies.
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    What is the difference between an Intellipro and a IntelliFLO?
    14x30 PebbleTec(Caribbean Blue) 12,000 Gals BORAX
    Pentair IntelliFlo <<>> Pentair FNS Plus DE
    Pentair 5G Intellibrite w/Intellibrite Controller
    ROME Solarium 125 Heat Pump
    Kreepy Krauly Classic <<>> Pentair 320 Feeder
    no-mas's Avatar
    Jun 2008
    FL
    405
    intellipro = sta-rite
    intelliflo = pentair
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    OK, Thanx!
    I saw this and got confused!
    http://www.staritepool.com/pool-pro/...ed-pump-78.htm
