Thread: plaster surface
    plaster surface
    mixed cyanuric acid with water in a bucket swirled it for few minutes before pouring it in the pool . ran the pump for 8 hours before turning it off . in the morning there was discoloration on the plaster where the acid was . wandering if there is any remedy for plaster surface
    22,543
    Re: plaster surface
    Were you using liquid or granular CYA?
    If it was granular, was it completely dissolved or were there granules left sitting on the bottom?
    Re: plaster surface
    there were granulars left not completly dissooved
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: plaster surface
    Describe the stains, or better yet, post a picture. I'm visualizing white freckles against the pale blue-grey plaster. That's what I had. Turns out the white is the plaster, the other color was calcium scale, a nice, uniform coating.
    22,543
    Re: plaster surface
    CYA is a mild acid and usually not an issue unless left laying on a surface. If you're lucky it will be scale as Richard says and keeping your FC at the top of the recommended level for your CYA for a while it'll fade and become uniform again. Even if it's not scale it will become more even over time, it just takes a lot longer.
    We recommend adding CYA to a sock in front of a running return or putting it in a skimmer and running the pump till it's dissolved.
    Re: plaster surface
    Thank u for the responses , with understandig of the issue it already feels better . It is the scale and i can see by time it becomes right again.
    Thank u
