Thread: Heating...new plaster
    Jul 2011
    Las Vegas, Nevada
    139
    We recently finished plaster and have been diligently sweeping. Final inspection is scheduled tomorrow for the gas test and tag and then I can get the gas installed and will be ready to heat the spa. The plaster company said that I couldn't heat the water for 30 days though because of the curing process of the plaster. Then one of the other guys with teh plaster company said to wait at least 5 days before heating the pool. We just want to heat the pool to a comfortable temp, maybe 80-85 degrees or so. Right now it is sitting steady at 68 since we filled it. We also would like to heat the spa for our Halloween party which is 20 after the plaster was done. Some friend of ours who just built a pool said it has to be 30 days to even use the solar cover.
    Jay...12,500 gallon freeform pool and attached spa w/ Bullfrog Oscillator & ClusterSpray Jetpaks
    Jandy 2hp VS pump(main), Jandy 2hp Stealth pump(Jetpaks), Jandy 1hp Stealth pump(water features) Jandy CL-580 filter, Jandy Watercolors LED lighting, Jandy Aqualink RS8(revision MM) w/Aquapalm, Autelis Controller, Onetouch controller, Jandy Aquapure 1400 SWG, Jandy LXi 400k heater, Paramount PV3 6 zone infloor cleaning system
    Re: Heating...new plaster
    I certainly wouldn't run the heater in the first few days. After that you could run the heater, but there are risks, especially at the higher temperature of a spa. Higher temperatures will speed up the PH increase, and heater plus high PH can cause scaling in the heater, which could damage or destroy the heater.
    Mar 2011
    Hazelton, PA
    57
    Wait the 30 days!
