Results 1 to 13 of 13
Thread: Getting picky - how to get pool to sparkle
    surfhawaii's Avatar
    May 2011
    Kailua, Hawaii
    63
    Thru this site's advice, I've been very good at keeping chem levels up to your recommendations. I test every three days and typically add 1.5 gals of clorox every 2-3 days and MA every 3 weeks. Water is never cloudy and I don't have any problems. But, and maybe I'm expecting too much, water doesn't seem to sparkle like it used to when I completely drained and refilled pool. It's clear and I can clearly see details of drain at deep end, but lacks luster.
    All chemicals are within pool calc recommendations...I stay on top of this. I don't backwash filter that much, maybe once a month.
    Is it just my imagination or can the water look, I don't know...dull? And, if so, how do I get it sparkly clean?
    22k gallon, Sand filter (Triton II TR 100)
    IG tile
    Pentair VS pump
    SWG
    Sundance Chelsee spa
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Getting picky - how to get pool to sparkle
    A dull look can be the first sign of an algae bloom.
    Try raising the FC level or just go ahead and shock the pool and retest.
    Posting a full set of test results would help.
    You're done SLAMing when:
    Mar 2010
    Spring, TX
    1,082
    Also if you can I would try for a few weeks to test everyday and see if it improves. With maybe testing every 3 days some levels are going to low or high.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    tgmb's Avatar
    Jul 2011
    san jose, ca.
    92
    Try a bit of DE, or try http://www.recreonics.com/cgi-local/...y=21-205&qty=1. Borates as mentioned above. Additionally, what's your filtration time? Are you running it long enough?
    20k gal. 36' In ground Med. Blue plaster, two-speed EcoPump EP6, Pentair 3.14 sq. Ft. Sand w/zeosand, Spectralight SL 500, RayPak 2100 heater, Polaris 360,GE Timer 15087, Borates 80 ppm.
    surfhawaii's Avatar
    May 2011
    Kailua, Hawaii
    63
    Ok...shocked it. Seems to have helped. Test results today:
    FC = 14 (is this ok to swim in?)
    CC = 0
    PH = 8 (will add MA today to lower this)
    TA = 75
    CH = 275
    CYA = 45
    Read the sticky note on borates. I guess you're going to tell me it's personal preference, but do I really want to get into this? I thought I read earlier in my pool school classes that this wasn't necessary?
    Thx, Ben.
    IG tile
    Pentair VS pump
    SWG
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by surfhawaii
    CC = 0
    TA = 75
    CH = 275
    CYA = 45
    Thx, Ben.
    Borates is a personal preferences. I myself have never seen the need to add them as this is just something else you have to test for and keep up with. Everyone that uses my pool along with myself like it the way it is. So I would say if you have no issues without borates then dont add them. This is just a personal preference to me though and others may disagree with it.
    Feb 2008
    Denton, TX
    5,061
    A FC of 14 can give a falsely high pH reading. Let the FC come down to < 10 ppm and then recheck pH. Correct it then if needed.
    If raising the FC improved the clarity of your water, then I would claim success. Borates can be sort of useful when additional pH buffering is needed. Pools that are clean sparkle without them though. I wouldn't add borates just for that. That's just me though.
    surfhawaii's Avatar
    May 2011
    Kailua, Hawaii
    63
    ok, thx. I guess since no one said anything, FC = 14 is ok to swim in.
    IG tile
    Pentair VS pump
    SWG
    Feb 2008
    Denton, TX
    5,061
    Not recommended to swim while shocking. Up to you. Probably end up bleaching your swimsuit a bit.
    surfhawaii's Avatar
    May 2011
    Kailua, Hawaii
    63
    swimsuit?! who uses a swimsuit? )
    IG tile
    Pentair VS pump
    SWG
    Feb 2008
    Denton, TX
    5,061
    Apr 2011
    Murrieta, CA
    2,360
