Results 1 to 8 of 8
Thread: new plaster and water
    Oct 2011
    Chico, California
    20
    Need some newbie advise.
    Our pool is old and was just re-plastered (not sure what product they used)
    They sprayed a new coating (plaster?) on it yesterday and said it needs to be 'watered down'
    3 times per day. Didn't get any real detail and can't reach them by phone.
    Any thoughts on what I should do over the weekend (its Saturday morning now) ?
    Bukzin
    Older in-ground pool, multi speed pump, 4 cartridge filters
    used clorine tabs for years, going to bleach and BBB method, 450 sq ft filter
    25,000 gallons, Polaris 280 sweep, city water, on septic
    very low usage pool, Wall Whale brush
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: new plaster and water
    Go ahead and spray it down as they said. Here is the Pool School article for plaster start up. If the information in the article is different than what the builder has told you to do then follow the builder's directions. Then if there are any problems he won't be able to say you caused it by not following their instructions. Have they refilled the pool yet?
    Love TFP? Become a
    TFP Supporter!
    Oct 2011
    Chico, California
    20
    More detail.
    The pool is in ground in California. Weather this week is mild (no rain, temps low 50, high 75)
    We got no detail from the pool refinishers (well respected local plastering company)
    Pool has not been refilled as yet.
    Thanks for the help!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Welcome, Bukzin!
    I'm a bit confused by your post; most of the time when a pool is replastered it is refilled pretty much immediately. Any chance you can post a picture of the new surface?
    Oct 2011
    Chico, California
    20
    Yes I will get photos ASAP
    I think what has been done so far is the pool company has applied
    just the first coat, not the plaster. (Can't get them on the phone)
    Does this first coat normally need water sprayed on it twice a day
    for the first 3 days?
    Aug 2007
    near the swamp
    806
    what plaster are they using?
    Fresh plaster needs to be kept wet. Normally this is done by filling the pool immediately, but it is possible to delay filling the pool as long as you keep the plaster wet for several days and it doesn't get too hot (mid-summer in the desert would be a problem). If the plaster dries out during the first few days it will crack.
    Jul 2011
    Arizona & California
    803
    From what I have gathered in reading the above posts, I think the plasterer has only applied a somewhat rough "bond" coat that needs to cure and harden for several days before being replastered. It is not the final smooth plaster coat. The plasterer will come back and perform the actual replastering to bond with his first application "bond coat" and then will fill the pool immediately afterwards.
