Thread: Stenner pump chlorine injection spot - inlet for tab feeder?
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    I just got my pump and am getting it set up.
    Is it ok to use the threads from the tab feeder for the injector?
    http://i219.photobucket.com/albums/cc25 ... a7dd20.jpg
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    Re: Stenner pump chlorine injection spot - inlet for tab fee
    You want the injection point to be after the pump, filter, and heater if any. If I am interpreting your photo correctly, it looks like your current point is before the pump.
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    My photo isn't very good, but it is after the filter on the return.
    It is the threads that the hose from the tab feeder use. I unthreaded the feeder and put the injector in.
    Some posts mention tapping the PVC? Just to clarify what they say I can drill a 1/2 inch hole directly onto the PVC pipe and then use a tap to give this hole threads and when I put the injector in it will seal?
    Jandy 2 speed pump
    22,553
    Tab feeders are usually after the filter and since yours is, it's ok to use the point.
    It's fine to drill and tap the PVC pipe as long as it's hard pipe. Each tap has a specific size drill to drill the hole with. A lot of them have the corresponding drill size stamped on them and all you have to do is look on the tap. If it doesn't you can look it up online.
