Results 1 to 8 of 8
Thread: LED light or Regular light?
    We are signing our pool contract tomorrow and trying to make final decision on our lighting. Right now the way the design/contract the pool will have one regular light in the end of the pool. The pool is going to be a 17x32 freeform. Trying to decide if we want to do an LED light or not...would 1 LED be enough or would we need 2? Then what is the typical cost of the lights? Any opinions woudl be appreciated
    15k freeform shotcrete sport pool 3.5-5-4, hayward swimclear c4030, 1.5hp hayward Northstar pump, polaris 280 with hayward booster, hayward turbo cell swg
    South Central NJ
    3,192
    Re: LED light or Regular light?
    LEDs give you colors and light shows.
    Regular lights give you one color.
    LEDs use about 75 watts.
    Regular lights use 300 to 500 watts.
    LEDs never need bulb changes. They have very long MTBFs.
    Regular lights need bulbs and gaskets and some know how. Bulbs can go at any time. Being 300 to 500 watts, they get hot in the fixture even though the glass lens and metal shell is cooled by the pool water. Heat kills components.
    LEDs, when using colors, don't put out as many lumens, the common measure of how much light is emitted.
    Regular lights, while brighter, often are glaring to swimmers and people around the pool at night.
    I would suggest, if you can afford it, two LEDs. This will provide an even glow. They aren't cheap but doing it right the 1st time vs. the Coulda Woulda, Shoulda feeling later is there as long as you own the home.
    Scott
    Owner of - PoolGuyNJ LLC
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Don't forget you could always upgrade down the road if money is an issue. Replacing a light is pretty easy.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    I had thought about the upgrading down the road, but thought with LED I may need 2 lights and I dont think it would be possible to add a light on the other end of the pool. Will talk with builder in the morning and weigh our options. Trying not to spend any more money, but don't want to wish we would have done something and not be able to down the road.
    If you do go with multiple lights, I recommend putting them on separate switches so that you can control them individually.
    Support the site
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    I have also noticed that using the yellow LED color greatly reduces the number of bugs that land on the water trying to follow the light. If we're not in the pool, however, I prefer the blue color.
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
    Oct 2011
    15
    Get the regular 110v then upgrade the bulb for $150. Find it on eBay.
    Green1340's Avatar
    May 2011
    Kemp, TX- 50 mi. south of Dallas
    55
    Jaime,
    Adding to PoolGuy's comments: We recently completed our pool and struggled with one or two LED's. We went with one LED and now regret the decision. $500 was the reason we went with one and not two and that would have been $$$ well spent if we had chosen the second light. If the pool was relatively straight the one LED would "probably" have been efficient. But we have a slight "dog-leg" going to the tanning ledge and this area has somewhat of a shadow on it which is where the steps are located.
    If possible, go with two LED's, switched seperately and you will not regret it.
    Greenhaw
    Freeform Gunite, 21K Gallons, Gray Plaster, 570 sq. ft., 106 Perimeter.
    Pentair- VS 3050, Intellichlor IC-40, 520 sq. ft Cartridge Filter, Intellibrite LED.
    Sun Touch Controller, Legend Platinum Cleaner with Pentair 1.5 hp Booster Pump.
    2- Bubblers & 2- Deck Jets. Autofill & Overflow. TF-100-Test Kit.
