My Pentair MiniMax NT heater won't ignite. The green "pressure switch" is NOT lite, only the "power" led is green. The DDTC display reads "OFF" even when the pool is running.(it usually display the pool temperature). Water pressure appears normal. Gas pressure is within tolerance. What would cause the DDTC to NOT read the pool temperature? Could I have a bad water pressure switch?
