Thread: How much of an salt increase with 1 or 2 TriChlor pucks ?
    susa's Avatar
    Oct 2010
    Deep South
    578
    Measured Salt level today 3150 and want to raise to about 3700-3900 (pools stats in sig)
    Since I also need to increase Cyanuric Acid by about 10-20, would 2 TriChlor hockey pucks be sufficient to raise Salt to that level ?
    How much would a 2.5 gallon(12%) liquid bleach container(from Leslie's) raise salt ? My estimate is around 500-600ppm for the liquid, not sure about the 2 hockey pucks.
    Yes, I know it is easy to add CYA and Salt separately but I have a large supply of unused Leslie's TriChlor pucks so wanted to see if this would be a simple way to achieve (1) increase salt, (2) gently increase Cya, (3) deplete tab supply slowly
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: How much of an salt increase with 1 or 2 TriChlor pucks
    Assuming those are 8 oz pucks, http://www.poolcalculator.com/ says each puck will raise FC by 3.7, raise CYA by 2.2, and raise salt by 3 in your 15000 gallon pool
    susa's Avatar
    Oct 2010
    Deep South
    578
    The tabs are called 3-Inch Jumbo Tabs, no reference on container to oz or grams
    320 oz (2.5 gallons) liquid would raise salt 27-34
    Richard320's Avatar
    Jan 2010
    18,988
    Quote Originally Posted by susa
    They're either 7 or 8 oz. Either way, it will take a lot of them to affect CYA and salt!
    If you don't have a postage scale or a diet scale in the kitchen, put one in a baggie and bring it to the grocery store the next time you go and ask them to weigh it when you get to the register. Or take it to the post office, there's usually some sort of self-service scale in the lobby.
    Feb 2008
    Denton, TX
    5,061
    Important note to all husbands...please, PLEASE don't use your wife's diet scale for measuring chemicals without asking first. They HATE that. Ask me how I know.
    30,419
    Susa,
    You are making it a little too complicated. Raise CYA by adding CYA....you'll need what's left over in the Spring.
    Raise salt by adding salt.
    Now you're done!!
