Thread: Is This Acceptable?
    Jul 2011
    Broken Arrow, OK (Tulsa)
    295
    Is This Acceptable?
    Just curious about this....
    Our build began last week, and all of us knew our sewer line would need to be rerouted during the project.
    I guess I assumed they'd figure out the exact location of the sewer line while digging out the pool. I was a little surprised, after being out of town for a few days, to come home and see the pool dig was done, with the sewer line running across it, still intact.
    I questioned our PB, and was told they're going to gunite the pool with the pipe in it, then, after the gunite's cured, run a new sewer line and cut off the existing sewer pipe running across the bottom of the pool and use hydraulic cement to patch the areas where the pipe came through the wall on one side, and thru the bottom on the other side.
    Our pool builder said he's done this before, and that the structural integrity of the pool isn't compromised. We were told that, after plaster, we won't even know where the old sewer pipe used to be.
    Is what we're being told accurate? (I'm out of town again, and will be surprised if they're able to steel and gunite around the pipe without breaking it!)
    This must be the part of the build process where we just have to trust our PB?
    16 x 31, Approx. 12,000 Gal Freeform IG pool; Flagstone coping; Quartzscapes Super Blue plaster finish; Tanning ledge w/2 bubblers; 1 HP Pentair Whisperflo pump, Pentair sand filter; (2) Pentair Intellibrite LEDs w/controller; Easytouch8 w/IC-40 SWG; Salt finish concrete decking.
    22,553
    Re: Is This Acceptable?
    I would have figured they'd have rerouted it before they built the pool but their plan is fine. They are correct that they can seal the pipes up and you'll never know it. They're also correct in that it won't affect the structural integrity of the pool.
    Aug 2007
    near the swamp
    806
    http://kaibass.com/pool_project.htm
    seen it in a few build logs before
    Jul 2011
    295
    Thanks guys! It's reassuring to know this isn't going to affect our build in a negative way.
    SCEADU's Avatar
    Feb 2010
    Atlanta,GA
    68
    In some places it requires a licence to run sewer lines. That might be the case in your area
