Results 1 to 12 of 12
Thread: Pentair IC-40 problems
    Just thought I would add to the collective experience we have here.
    The salt sensor failed on a 5 month old unit. Warranty repair took 3 weeks.
    It has now failed again, 2 days after repair.
    So far, Pentair has been responsive if not quick. We will see how the latest problem gets handled.
    At this point, with the experience here coupled with my own, I would not buy another Pentair SWG again.
    I will let you know the outcome.
    33,000 gal vinyl
    Pentair IC-40 SWG
    Hayward sand
    1 1/2 Hayward Super pump
    Full sun
    South Central NJ
    3,192
    Re: Pentair IC-40 problems
    That is very unusual.
    How did you determine it was the sensor? Like most cells, it uses conductivity to determine salinity.
    Where was the dealer?
    Scott
    Owner of - PoolGuyNJ LLC
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Agreed; sounds like something else is going on.
    There may be another problem, although he said he replaced the salt sensor. The tech said he would come by this week.
    The symptoms were/are salt low, red light, cell off with 4000 ppm salt.
    Over the summer the low salt light would come on, never flashing, always red solid, showing the cell off. True enough, it would not produce chlorine until I raised the salt level.
    After the third time this condition repeated, I bought some salt test strips and checked the level before I added salt. Showed 4000 ppm in 3 different tests.
    The rest of my numbers are right on TFP standards.
    33,000 gal vinyl
    Pentair IC-40 SWG
    Hayward sand
    Full sun
    Oct 2009
    3,899
    Well, please keep us updated.
    susa's Avatar
    Oct 2010
    Deep South
    578
    ask the tech to analyze the cell using a pentair intelliwand, it will also measure salt level but more importantly, show all the powerlevels and runtimes historically, ie. analyze the lifespan of the cell in hh:mm:ss
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    As another reference, I've got a Pentair IC-40. The only problem I had with the original was that one of the LED lights didn't work. It took them about 2 weeks to come out and replace the unit, although I wasn't in a hurry since it was working well. I got a new one and it has run all season without issue.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Feb 2011
    Petaluma, Ca
    665
    I have a similar situation where the ic-40 shows "low salt" right now (2500ppm), it is still generating chlorine though untill approx 2300 ppm according to pentair. The taylor test has consistently shown approx 700 to 1000 ppm higher than the ic-40. I think the sensors in these arnt that accurate, or at least the one I got. one day this summer it was reading low salt (2700 ppm), the next day it was good (3300 ppm), the next day low salt again. (2600ppm). Kind of lame if you ask me.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    May 2011
    36
    HMMM, I know this post is kinda old and I like to explain things.
    1) When using SWG, Keep you eye on your other chemicals, PH, TA, CH, Temp, Etc.
    2) Keep note on your SI Index.
    Based on the water passing in the cell will determined the voltage that is pulled off those blades.
    The cell use that voltage based on the water temp to find out the salt readings. (This is why they tell you to clean the cell too)
    If the voltage pull is wrong then the readings will also be wrong.
    Its not that the cell is showing readings jumping around. Its your water chem thats jumping around due to the water temp changing or something else.
    Always look at the SI!! If your pool store tells you that they dont know what it is then find another pool store lol
    Feb 2011
    Petaluma, Ca
    665
    After they replaced mine a week ago the salt reading from the ic-40 has been steady at 3450ppm, my test 3600ppm, the warranty guy 3400ppm. Seems like its working right now, the old unit was reading approx 2400ppm when it was replaced.
    susa's Avatar
    Oct 2010
    Deep South
    578
    I've had good success in matching tested & Cell reported via IntelliWand salt readings on two family pools and my own, sticking to a very precise testing schedule and keeping all values tightly in range. I've also cleaned filters once a month (all cartridges so quick and easy) even when not required. It helps to have the acid injection occur into the line before the IC40 cell, apparently keeping the blades clean with small measured bursts of MA.
    Sep 2008
    Melbourne, FL
    141
    I realize this thread is dated, but I wanted to pass on that my IC-40 seems to be working well (making chlorine that is) however like one of the posts above, I have an LED that is not working ... the Cell "status?" light. It is neither green (normal) or red (bad?). I'm 2 years into my 3 year system warranty. Pentair has been extremely responsive in the past year when my spa and pool lights would not sync up. We'll see how this new anomaly pans out. I'd expect the same quality service as everyone has been touting ... stay tuned.
    KARL
    Karl
    Freeform 15x31 Pool w/ oversized spa, 1 1/2 HP Blower, Pentair Quad 60 DE Filter, Heliocol solar panels, Pentair Maxitherm 400K BTU heater, Pentair IC40 SWG, Pentair Easytouch 4 w/wireless remote, Pentair IntelliFlow VSP, and Pentair Intellibrite LED Pool/Spa lights.
