Thread: Schrader Valve Blow-Out. Compressor or Mighty Vac????
    Does anybody know if an attachment can be made to use a mighty vac to connect to a schrader vavle for blowing out the lines? Is this only a compressor specific thing,....or could a mighty vac be used in this situation as well?
    Thanks.
    16'x24', 14k gal, in-ground vinyl rectangle pool, Hayward S-180T sand filter with 1.5 hp pump
    Jun 2007
    New Jersey
    653
    Re: Schrader Valve Blow-Out. Compressor or Mighty Vac????
    Making one would be easy. But I seriously doubt any Shop-Vac/Mighty-Vac/blower type machine could generate the pressure to get much air through the very small aperture of a Shrader valve. Those machines are good at large volumes at low pressure, and getting air through a small valve opening needs very high pressure.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
