Results 1 to 14 of 14
Thread: closing pool 1st time
    Apr 2010
    Central Illinois
    205
    Hi,
    We are having the pool store close our pool the week of Oct. 17 (won't know exact date until Oct. 15)
    Can I shock the pool now?
    They told me to stop running the filter and drain the pool about 2 inches under skimmer about 1 week before they come....If I do that I obviously can't run the filter or shock it!!!
    Is there any reason why I would need to stop running the filter that soon?
    When is the best time to Drain the water before they close the pool? (a day, a week, ?)
    Thanks a ton!!
    15x30x54 AquaLeader Sentinelle AGP
    2 HP 2 Speed Hayward SwimPro Voyager Pump
    Hayward SwimPro Voyager 150 sq. ft. Filter
    Hayward H series millivolt 150 btu Heater
    TF-100
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: closing pool 1st time
    I would shock it the day before, drain it right before they come. I wouldn't wait a week.
    Apr 2010
    Central Illinois
    205
    Is it okay to close it with the FC at or above shock level or does it need to be at a certain number?
    TF-100
    11,969
    At or slightly above is totally fine.
    Apr 2010
    Central Illinois
    205
    I read in a few posts that said to shock and let it drop to around half the shock level.....is there a difference in closing at shock level or half shock level.
    I just want to open to a nice clear pool in the spring.
    Thanks again
    TF-100
    Apr 2010
    Central Illinois
    205
    anybody there?
    TF-100
    22,550
    There's not really a difference. It's easier on the cover, etc if the Fc isn't too high. HAving said that, I shock and cover immediately. Next spring I'll still have a good FC level to start with.
    Apr 2010
    Central Illinois
    205
    Ok, I'm shocking pool tonight (hopefully I get a response soon) My cya is between 20 and 30. The chart says shock would be 10 or 12.....the next one is 16 would it be a bad idea to raise it up to 15 today and not add anymore bleach and close it with whatever the level gets down to on Tuesday. The pool is being closed on Tuesday. We are going to drain the water tomorrow afternoon....is it ok to drain it that close to closing?
    Thanks so much.
    TF-100
    22,550
    Raise the FC, lower the level and cover it.
    Apr 2010
    Central Illinois
    205
    what i need to know is 15 too high?
    TF-100
    22,550
    What does the Chlorine/CYA chart say? You can go a few points above that without damage.
    Apr 2010
    Central Illinois
    205
    Alright, Pool Store came and closed pool...here's what they did:
    *drained water from filter/pump
    *removed hoses from skimmer and to return
    *blew out lines (I wasn't out there for this part)
    They didn't add antifreeze, they said it didn't need it.
    *Put cover on pool
    Will everything be okay without antifreeze
    Is there anything I need to check? (make sure no water left in filter etc.)
    Also should we cover all of our equipment, the pool store said not to cover heater or filter ?
    Thanks in advance
    TF-100
    Apr 2010
    Central Illinois
    205
    Hello?
    TF-100
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Take some pictures and post them of your pool. Removing hoses and blowing them out doesn't make sense unless im reading it wrong. I tell people not to cover the heater or filter too because wrapping them in tarps tends to trap moisture and then the sun heats the trapped moisture. Building an open walled structure over them to keep off snow and rain is okay. Pictures will help
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
