Results 1 to 17 of 17
Thread: Indoor pool test results
    Jul 2007
    Suwanee, GA
    528
    I've been taking my kids to swim lessons at an indoor pool since the summer and they always come back reeking of chlorine. I've wanted to test the water myself, but never remembered to bring a bottle. Well today I took my bottle and grabbed a small sample. Here are the results:
    FC = 13
    CC = 3
    CYA = 0
    PH = 7.8 - 8.2
    TA = 16
    CH = 210
    This was from the pool that all the little kids are in, I'll test the others over the next few times I go. My kids do swim in this pool when they are done, but spend most of the time in a larger pool. I'll sneak a peek at that one next time.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    That is awful. FC is way to high, CC is way too high, PH is high, and TA is low.
    Guest
    It is possible that the FC is actually higher then you tested but it lost strength by the time you got it home to test. IF this is true then the chlorine could be high enough to cause the pH test to be reading high. I would almost bet that the pH is actually too low, which is why the TA is reading so low! (assuming you are using Taylor test reagents or the TFTestkit.)
    Jul 2007
    Suwanee, GA
    528
    Well, the PH was done with a kit like this:
    http://discountpooldepot.stores.yahoo.n ... lplus.html
    and the rest was with the TF100. I took the water on the way out the door, but it did take us about 45 minutes to get home because of a pitstop at Krispy Kreme.
    Water temp in the pool was 90+
    Gary
    Jul 2007
    Suwanee, GA
    528
    BTW, they use the Taylor 2005 test kit. Next time I'll take a look in the log book to see how they record it.
    Gary
    30,432
    Well, it's nice to see your priorities are in order
    Jul 2007
    Suwanee, GA
    528
    ouch, you're full of good ones lately
    I just realized that the TA was an error. I wrote down 16, which was the number of drops.
    TA = 160
    Gary
    Guest
    some of the Rainbow (Pentair) kits have a phenol red that has chlorine neutralizer built in and some of them don't. If yours has the one with the neutralizer included in the reagent it is as accurate at the Taylor or TF100. If not you will get a high pH reading with chlorine levels not much above 3 ppm!
    Mar 2007
    San Rafael, CA USA
    12,082
    I think the main problem here is that this indoor pool is WAY over-chlorinated. It's bad enough to have "normal" Free Chlorine levels (say, 2 ppm or so) in an indoor pool with no CYA, but to have 5+ ppm with no CYA (and at least 13 ppm FC in your case) is a heck of a lot of chlorine. You should really complain to the owner of the facility and have them get the chlorine level more in line. At those high chlorine levels, it's not just a matter of faster swimsuit degradation and skin flaking and hair frizzing, but the amount of smelly disinfection by-products, specifically nitrogen trichloride, may be close to levels that can cause respiratory and ocular problems.
    I assume the 13 wasn't the number of drops in the FAS-DPD chlorine test. If it was and the sample was a 25 ml sample size, then that's really 2.6 ppm FC; if the sample size was 10 ml, then 13 drops would be 7.5 ppm FC.
    Richard
    Guest
    wow, i need to turn down my clorinator then. my pool read 15ppm for clorine all year. no wonder it felt funny to swim, were hurting our lungs. but never a smell and you only get the clorine smell with CC.
    every indoor pool i swim in always smells like clorine, im guessing because they never get rid of the CC's/
    Jul 2007
    Suwanee, GA
    528
    13 is the correct FC reading because I remember laughing when it hit 20 drops, to a total of 26 with a 10ml sample.
    The Pentair kit that I've been using has a separate 'chlorine neutralizer' that gets added before the ph drops. I've found this one easier to match the colors over the Taylor one that was included with the TF kit.
    Thanks for your input guys.
    Gary
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by Rollin Thunder
    Vince,
    Your pool is outdoors, isn't it? So it has CYA in it, doesn't it? In that case, 15 ppm FC isn't as high as you might think, depending on the CYA level. If it's an SWG pool with 80 ppm CYA for example, then the 15 ppm FC is equivalent to 0.2 ppm FC with no CYA so isn't horribly high. It's still higher than needed to prevent algae, but is far lower than found in indoor pools that have no CYA.
    Some indoor pools do have CYA -- too much CYA -- because they use Trichlor feeders. In that case, the high CYA can lead to a slow breakpoint so monochloramine builds up and that can smell. At the other extreme, with no CYA, the breakpoint is too fast and you get more nitrogen trichloride which is really smelly and irritating. Usually, though, you don't get these situations unless the bather load is high, but in many commercial and public pools that is the case.
    Richard
    Guest
    [quote=chem geek]
    Quote Originally Posted by "Rollin Thunder":1mb1orgz
    Vince,
    Richard[/quote:1mb1orgz]
    yes she is outdoors
    my chems are all screwed up and i plan on fixing it this new season now that i have aton more time on my hands thanks to a little thing called retirement 8)
    but my last CYA reading was like 210 (NO NOT A TYPO) the dot disapeared with only like 1/4 of an inch of water in there, had my son check it too and he said he could not see the dot also (at waist level like the box says) so does this mean i need to drain and refill then, because if i do i want to ready my check book as thats alot of dollars worth of water.
    Guest
    Quote Originally Posted by crabboy
    This is the kind that will read high when the chlorine gets aroudn 3 ppm or so!
    Mar 2007
    San Rafael, CA USA
    12,082
    yes she is outdoors
    Ah, so the "auto-chlorinator" is probably a Trichlor feeder. For every 10 ppm Free Chlorine (FC) added by Trichlor, you are also adding 6 ppm to Cyanuric Acid (CYA) so that built up over time. You eventually will need to dilute your water, but don't have to do so all in one shot which is more expensive. In the meantime, with a CYA of 210 ppm, you would need to have a minimum of 16 ppm FC to keep away green algae so that's about what you've got right now. However, to keep the CYA from continuing to increase, you should consider switching to using chlorinating liquid and possibly getting The Liquidator (see this thread for more info) for automated dosing. If you regularly backwash your sand filter, then you should dilute your water over time and the CYA will get lower (assuming you stop using Trichlor tabs or Dichlor powder/granules).
    Your other alternative that would let you use a lower chlorine level, perhaps half (so around 7 ppm) would be to use an algaecide such as PolyQuat 60 weekly. However, this can get expensive.
    Richard
    Guest
    [quote=chem geek]
    Quote Originally Posted by "Rollin Thunder":2w35lvsb
    yes she is outdoors
    Richard[/quote:2w35lvsb]
    im not in to the pool lingo yet im guessing auto clorinator is more like the salt system. which this season im planning on upgradeing too anyway. but i just thought that somthing that added the clorine in there my self with out having to measure it was auto DOH. but yes i throw the giant rollaids in there usually put about 10 pucks in and refill twice a week. too much? its costing me a ton in clorine so i may switch to bleach before i upgrade to a salt system.
    Mar 2007
    San Rafael, CA USA
    12,082
    Well, it's up to you, but for every 10 ppm FC you are adding with Trichlor you are also adding 6 ppm to CYA. I think you would be better off going to chlorinating liquid, but of course you do want SOME CYA though that won't be a problem since you can just do partial drain/refill and backwash over time until the CYA drops to some reasonable amount around 30-50 ppm or so. If you do get a saltwater chlorine generator (SWG), then the CYA level recommended may be closer to 60-80 ppm. Right now, you may be finding an unusually high chlorine demand due to algae growth that you can't quite see yet (the water would start to turn dull and then cloudy before it turns green if algae takes off). That's what happened to my own pool years ago when I used Trichlor and my CYA got up to around 150 ppm -- I noticed the chlorine was getting used up faster "mysteriously" though now I know what was really going on. At your current high FC level, you're probably just keeping algae away.
    Richard
