Thread: Solar pool cover
    Solar pool cover
    I have just started using a solar pool cover which has strong edging. but the coping stone around the pool is quite rough. so each time i wind in, or take out the cover from the roller the cover is rubbing rather viciously against the coping. any ideas?
    http//:a-brit-in-spain.blogspot.com
    8 x 4 gunite inground
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Solar pool cover
    Is your cover on the end of the pool? If so, you can move it forward a short distance so the cover doesn't drag on the coping while you use it, then move it back into position when done.
    Thanks i have it forward but the Edges chaffe on each side of the pool between the water and the roller i am experimenting with two pieces of tarpaulin at the point i mention and it seems to be working.
    SW Indiana
    9,199
    Does your coping protrude above the water? If so, your tarp solution might be your best choice.
