Thread: winterizing filter hole
    I have an Intex 24' x 52" ultra frame. I lowered the water below the filter holes and removed the plastic parts. I added the winterizing chems, put in a pillow and covered it with a winter cover. It has rained and now water is coming out of the filter holes. I have tried to find something to cover the holes, but have had no luck. This is my first year leaving a pool up for the winter and would like any help. Thx.
    12K gallon, FF, IG plaster. WhisperFlo 1.5 hp pump. FNS-Plus Vertical Grid D.E. filter, 48 sq.ft.. Kreepy Krauly that scares the heck out of the grandkids:)
    Re: winterizing filter hole
    did you drain it 5 inches below the filter holes
    Ok, thx. I take it if I drain it down 5 inches, I would not need a cover for the hole?
    i have do not have an intex i just followed the winterizing instructions on here think i seen intex winterizing on main menue
