Thread: Wet Niche Conduit
    Jul 2010
    Miramar, FL
    9
    Wet Niche Conduit
    After removing the light fixture from my spa, I noticed there is no seal to prevent water intrusion into the niche (probably why it's called a "wet niche"). That also means the 1" conduit will always be filled with water - up to the water level of the spa, which is about 2' below the ThermoCraft junction box. This seems strange to me. Is this the way it is properly designed to be?
    14,000 gallon pool-spa combination.
    Cartridge filter.
    Inground pool.
    Shotcrete construction.
    3hp Pentair pump.
    Dec 2009
    Central Massachusetts
    2,690
    Re: Wet Niche Conduit
    Quote Originally Posted by markjones
    Yes
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Welcome to TFP!
    As bk406 said, that is the way they are normally done.
    Jul 2010
    Miramar, FL
    9
    Thanks! By the way, while digging around the spa with a shovel, the 1" coupler attaching a conduit elbow to the stub-out from the spa slipped off. That doesn't happen with properly glued conduit. Apparently the pool builder (Venetian Custom Pool and Spa) ran out of glue and decided to use PVC cleaner to "glue" the fitting. Unfortunately, he probably used the same method to glue all the electrical pieces together.
    Cartridge filter.
    Inground pool.
    3hp Pentair pump.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    I've discovered PVC conduit buried underground w/ no glue. I don't know what possesses electricians to bury conduit assembled as a slip-fit unit, but there seems to be a running theme.
    On a semi-related note, I also found a home air conditioner drain line assembled from 1/2" PVC pine which was not glued either. Something to consider when blowing out the drain. Now I always vacuum the lines w/ a wet-dry from outside instead of blowing it from the inside. Never assume, I suppose.
