Thread: My total alkalinity is 70 How much baking soda do I add?
    Hello. I'm closing my pool in the next few days. My water temp is 53. I'm following Jasons closing a ingound pool. He said make sure total alk is not out of wack. Thankyou.
    18k IG 16'x32' vinyl liner Haywood S-200 high rate sand filter pump Haywood Encl.3 1hp A.O.Smith Corp
    Re: My total alkalinity is 70 How much baking soda do I add?
    A TA of 70 is in the normal range (60-80 with a SWG or 70-90 without), so you don't need to add any baking soda. (The only exception would be if you are going to use trichlor floaters over the winter, which we don't recommend. If you are doing that TA should be higher.)
