Results 1 to 8 of 8
Thread: Is spectrum Algaecide 60 polyquat?
    Anybody.
    18k IG 16'x32' vinyl liner Haywood S-200 high rate sand filter pump Haywood Encl.3 1hp A.O.Smith Corp
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Is spectrum Algaecide 60 polyquat?
    If the ingredients say "Poly"-anything at the beginning, probably so. Most 60 and 30 algaecides are.
    It says,poly( oxyethylene ( dimethyliminio )
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by filix
    Poly"...."60% or 30%...then yes, that is the polyquat. Usually quuite a bit more expensive then typical copper based algaecide
    thankyou both.
    Mar 2007
    San Rafael, CA USA
    12,082
    Polyquat 60 should have in the ingredients 60% of "Poly [oxyethylene (dimethylimino) ethylene (dimethyliminio) ethylene dichloride]". It sounds like you've got the right stuff assuming you just truncated the name.
    Aug 2007
    near the swamp
    806
    yup if it had the active ingredient Poly [jharklshfjkardhfkjwhrkjlfgsdjkgfarwerfjhwegrfahjklfhjkrhghkh khdkhfehrfg] 60% then it is poly 60 lol
    I think that it is made by N. Jonas & Company, Inc. They are a private labeler of pool chemicals. They make the Spectrum line as a house brand. They make it under EPA registration number 3432-42, which corresponds to polyquat.
    They also make an algaecide-50, which is a linear quat, not polyquat. So, they could be easily confused unless you read the label.
    The linear quat algaecide will have a formula similar to this:
    n-Alkyl (60%C14, 30%C16, 5%C12, 5%C18) Dimethyl Benzyl Ammonium Chlorides-49.8%
    Support the site
