Thread: Can I downsize pump motor, keeping the same housing/strainer
    Jun 2011
    Florida
    15
    My pump motor is oversized for my pool. I currently have a 1.5hp, I would like to go down to the 0.75hp. My question is, can I replace the pump motor while keeping my existing housing/strainer? I read somewhere that I will have to change out the impeller to match the smaller pump size.
    I would rather not disconnect the piping, but if it makes the most sense to buy a complete new pump I will do that. Any thoughts?
    9.5k IG Pool
    Plaster (Diamond Brite)
    Sand Filter
    22,548
    Re: Can I downsize pump motor, keeping the same housing/stra
    You can change it as long as you change the impeller to match the new motor SFHP. While you're changing it you could go with a 2-speed model and that'll save you even more. If ou wanted to keep the impeller you could stick with a 1½hp model and still save a lot.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    May 2009
    Youngsville NC
    395
    You could put the smaller motor and impeller in, but by the time you add in the seal kit / etc - you'll probably find it more cost effective to just replace the pump (maybe put the old one up on Craigslist ? )
    You can find some above ground pumps that are self priming of your desired HP for around $200 -$250 that would work well for your situation. The Pentair Dynamo or the Hayward Powerflo II should both work just fine for your use - I was using a 28 year old powerflo II (without strainer) on my inground pool that is twice the gallons of yours with no problems until I got my replacement Superflo.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
