Results 1 to 12 of 12
Thread: Using the pool as a reservoir in case of emergency.....
    tgmb's Avatar
    Jul 2011
    san jose, ca.
    92
    If we were forced to use our pools for drinking water, how would we be able to safely do so? Chlorine is self limiting, and depending on your level on any given day, would quickly drift down.(Federal guidelines for drinking water chlorine levels list the recommended upper level at about 4 ppm.) CYA, from what I have read, is essentially non-toxic, unless mixed with Melamine-is that true? For Borates, the LD 50 is 2.66g/kg in rats; how that would that work out in a human at 50 ppm? (Would Borates be stored by the body, or eliminated?) Salt is rather self-explanatory. You would have to assume that you would be supplying adults, children, and animals, as you would quickly become a community supply point.
    So, hypothetical situation as follows. Power is down, no potable water available except your pool, which you suspect is not quite potable. What methods would you use to make it potable, based on, say: FC 4, CYA 40, Borates 50, pH 7.4, CH 300, TA 100. You could also work the problem with sodium 3000 ppm, just for additional complexity. (We'll hypothesize that since you use BBB, you have no algaecide in your water...)
    Tom
    20k gal. 36' In ground Med. Blue plaster, two-speed EcoPump EP6, Pentair 3.14 sq. Ft. Sand w/zeosand, Spectralight SL 500, RayPak 2100 heater, Polaris 360,GE Timer 15087, Borates 80 ppm.
    Feb 2008
    Denton, TX
    5,061
    Re: Using the pool as a reservoir in case of emergency.....
    I guess it really comes down to borates and CYA and whether or not they are safe substances is drinking water. Chlorine, calcium, pH, and TA are all components of most municipal water supplies and are delivered straight to the tap in most cases.
    Butterfly's Avatar
    South Carolina
    10,045
    You're done SLAMing when:
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    This issue was also addressed here.
    Love TFP? Become a
    TFP Supporter!
    Mar 2012
    12
    get a TFC RO unit and a 12v pressure pump. Stock up on iodine
    Pool cleaning service for Coral springs and all of broward. wet world aquatics Using science to give your pool and aquarium the best year ever.
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    I have not read the linked posts, but I believe it all boils down circumstance. After most disasters FEMA ARC and etc are pretty quick with bottled water. Pool water might be very beneficial for washing and other needs.
    If the pool is the only option for drinking water then I'd have to assume all **** has broken loose. Cancer risks from too much chlorine and other chemicals would be at the very bottom of the concern list. Dehydration can kill in 24 hours on a hot summer day - much faster then the chemicals will hurt you.
    Following this same logic when lost/stranded in the wilderness it can be advisable to drink water that is known to have Giardia. Sick in 48 hours is better then dead in 24 in a survival situation. Hopefully you will have help/ rescue by the time you get sick.
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    Mar 2007
    San Rafael, CA USA
    12,082
    Among other things, the posts mention how you can use water from your hot water heater in an emergency. That would normally be your first source of clean water if you didn't have bottled water available.
    Apr 2009
    Burlington, ON, Canada
    344
    Tankless hot water system here...guess I'll be drinking from the dog's bowl...lol.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Apr 2012
    151
    I have been pondering this as well, and my first order of business in an emergency will be to cover my pool, and hook up the genny to it. While I only have a porous safety cover, If I can filter it for ~3-4 hours a day with minimal sunlight getting in, I believe that I can keep it semi potable. I will also guard this diligently. While there are many sources of H2O near me, NONE are as clean and as desireable as my pool. I will still boil and filter.
    I can hunt and fish, but I will not squander the resource that I have in my backyard.
    Science and Math Teacher
    Owner - SPS - part time pool biz
    18x36 IG Vinyl, 23000 Gallons with Jacuzzi (the bane of my existance) pumpworks
    Polaris 280 w/ PB4 booster
    Apr 2011
    Warner Robins, GA
    245
    wow.......deep thoughts on Subject. I jsut dont find myself thinking about these things. I figure if it comes to that, then we are all done anyways. Nuclear fallout, bilogical pathogens....kinda makes worrying about drinking pool water non important in my book.
    Stock up on Beer- you'll be good to go!
    16 x 32 Grecian Vinyl. Salt-Aqua Plus PS-4, Hayward Pro Series Sand Filter, Hayward Ecostar SP34000vsp, Gulfstream HE-125-T-A Heat/Cool heat Pump
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Your neighbours and rampaging thugs will attempt to take your supply of water by force, or the gov't comes with a big vac truck to suck it up and "spread the wealth".
    I'm just sayin.
    Apr 2012
    151
    I can make beer from my pool water!
    I don't think about it a lot, just enough to have a plan.
