Thread: Barnacles in Pool
    Barnacles in Pool
    My in ground pool on Hatteras Island was covered with five feet of salt water during hurricane Irene. I just finally got down to inspect the house and pool and have found what looks like barnacles growing on sides and bottom of the pool. It's been a month since the pool had been running. Is there a special chemical I should add to the pool to kill these things. I'm closing the pool and would like to kill them so I don't have a problem in the spring
    cmlampa
    14 x 28 x 5ft
    Hayward Sand Filter
    11000 gal, IG
    concrete
    1 HP Hayward Pump with timer
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Barnacles in Pool
    If they're actually barnacles, chlorine will kill them. Kind of a unique problem!
    That being said, calcium scale often looks like tiny barnacles. Any chance of a picture?
    Jul 2011
    Central Califorina
    208
    In another life I was a navy diver and busted many barnacles off of ships. If you can get in the water with goggles and take a look at the suspects that will help. Barnacles are live creatures, you will see them extending filaments trying to catch and eat plantain. I don't think they could grow/survive in your pool. They need a living ecosystem to support life.
    What ever is growing on your pool sounds like it might have to be removed with some elbow grease. Maybe a pumice stone.
    3500 gallon 14x42 Intex Ultra Frame
    1/2 HP Intex 1600 sand filter/pump - Intex SWCG
    Two 4x20 Fafco solar panels.
    Taylor K-2006
    Marquis spirit hot tub - Grill Dome ceramic grill/smoker
