- Oct 5, 2011
- 2
Has anyone replaced their GFI in the control panel and found that the Jandy system power is tied into the GFI along with the pool lights. This makes sense such that if there is an GFI current leak between power and neutral, it will also shutdown all motors as required by code, yet the Jandy manual shows only the lights connected through the GFI. Am I wiring it wrong on the replacement as it now blows everytime. Is there a special GFI type required for pool applications? Suggestions welcome.
