Results 1 to 11 of 11
Thread: Pool Ozonator
    Pool Ozonator
    Does anyone have experience with pool Ozonators? Im talking about the device that feeds ozone in your pool that looks like an stereo amp that has a flow-through tube that continuously adds ozone. A couple of my neighbors have them (were standard with the pool) and of course, they don't know anything about them. Is this a gimmick or is it worth the cost?
    Thanks in advance!
    15.5k pool, BBB method used, Plaster in ground pool, DE filter, full sun in Boerne, tx, NO SWG.
    Re: Pool Ozonator
    Ozone is normally only worth using when you have lots of people swimming, for example in a commercial pool. Chlorine alone is more than sufficient in an outdoor residential pool, leaving hardly anything for the ozone to do.
    Re: Pool Ozonator
    Thanks for the reply! Now I can put that money towards bleach
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Re: Pool Ozonator
    I have one. It has never caused me any trouble, but I'm not convinced it does any good either. I would not buy again.
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    Re: Pool Ozonator
    Thanks for your advice! I think ill pass based on the feedback you guys gave me. i just wish they made an automatic liquid chlorine feeder that didn't have so many issues.
    Thanks again!
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Re: Pool Ozonator
    Jandy 2 speed pump
    22,544
    Re: Pool Ozonator
    The injection pump on a timer is about as simple and reliable as it gets.
    Re: Pool Ozonator
    Ozone is great in a pool- provided you have lots of money to spend. There is a lot of great commercial ozone units but with the cost of air dryers refrigeration, gas injection lines and destruction chambers, it would be clear to suggest that anything marketed toward retail is just theoretical.
    Remember that you will still need to balance pH as well so I would put by dollars into a good pH controller and keep it simple.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Pool Ozonator
    The cost of automating pH control may not be cost effective for you. When you test on a regular basis you can make small adjustments to pH as needed and may find the pH stays fairly stable when you keep the water balanced.
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Pool Ozonator
    Quote Originally Posted by AP
    Could you expand on this? For an outdoor residential pool exposed to sunlight and using the maintenance methods described in this forum, what are the benefits of using an ozonator?
    Re: Pool Ozonator
    In my opinion. Very little benefit given the parameters you have described.
