Thread: How much Clorox?
    May 2011
    State College,PA
    10
    How much Clorox?
    Closing our pool this week and instead of using the "winter kit" we normal get, we were going to put in Clorax and the anti algae. How much Clorox is normally used for closing a 13000 gal AGP?
    Todd
    15x30 AG, 13000 gal
    Sand Filter 22", 1.5hp, Flow/backwash rate 55 gpm
    Apr 2011
    Lynchburg VA
    393
    Re: How much Clorox?
    36-48 hours before you plan on closing the pool add the algicide (polyquat is what is recommended) to the water and bring your pool up to shock level using the pool calculator to determine the amount of chlorine you need to add depending on your CYA levels. Allow the chlorine level to drop to half of the shock level and button it up.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    May 2011
    State College,PA
    10
    Thanks! Reading and rereading in the pool school etc...........
    15x30 AG, 13000 gal
    30,426
    Tebpac,
    Have you found the "pool calculator" yet to help you with your dosages? Post back if you have questions.
