Solar panel pumping question
a_fan
0
Jun 7, 2011
19
I have a Pentair single speed 2hp pump. Distance from pump pad to pool is about 75 feet. Two returns and two skimmers. I want to add a solar panel setup in my system, maybe 2 - 4x20 or 2x20 panels mounted on the ground. I would tee off discharge of filter and return to same spot. Elevation changes very little.
My question is, is that too much piping for my pump to pump through? It would mean water would leave the filter, go 75 feet, through solar, 75 feet back, 75 feet to pool, 75 feet back to pump suction. I realize only a portion of the water is going through the solar.
Let me know what you think. Sketch attached.
  • POOL.pdf
