Results 1 to 12 of 12
Thread: Is stamped concrete dangerously slick
    Jul 2009
    Fort Wayne, IN
    392
    Would love some input from those in the know . We are considering it for the complete deck around the pool. I have had two people warn me it is too slick and dangerous TIA
    Theresa and/or Gary
    Complete DIY: 20x40' rectangle. Resin walls, vinyl lined. 33000 gallons. Full width steps. 8' deep. Diving board, slide. Hayward pro series super pump, sand filter. Raypack 336K BTU heater. Main drain, 2 skimmers, 3 returns, 2 amerilite lights with quick change lens Aquamatic auto cover and a partridge in a pear tree.
    Breaking our backs in the hopes that one of our six kids will care for us when we are old ;)
    MattM's Avatar
    Jul 2011
    San Diego, CA
    299
    Re: Is stamped concrete dangerously slick
    This is a very good question...
    I think you'll find that:
    a) most people will tell you not to do it, and/or if you do, don't seal it
    b) some builders/pavers have had bad experiences with the non-stick additives needing to be constantly reapplied or not being effective....this has given the whole topic a "beware of trying it" reputation.
    c) some pool owners have somehow found very experienced builders/pavers who know how to do it fine, and report that they are very happy with their sealed stamped concrete and have had no problems other than needing to remember to reseal every few years
    The above is based on my research over the last 3 months (talking to numerous contractors and reading online). We're giving sealed stamped concrete a try (using additives/etc) and our pool builder while initially warning us away, says they can comfortably handle the job even when we asked them point blank if it would be easier on everyone if we used a specialist for the decking. This is honestly the only area of our current pool build that we considered farming out. It appears that it can be done but the skills/knowledge may not be transferred too widely.
    If you get other or additional info, please post!
    24K gallon inground gunite/pebble sheen pool, 34'x16' 4-7.5ft deep, 750sq ft solar, pentair ultratemp, intelliflow vs+, ic60, intellichem w/ acid pump, quad de 100, intellibright 5g, intellitouch i5-3s with Screenlogic2, 3" primary piping - 2.5" at equip pad, auto switched deep heating and main returns, automatic safety cover w/ electronic lock and embedded recessed undertrack, sealed stamped concrete deck, dolphin deluxe 5, started up December 2011.
    Our stamped concrete is still new. The contractor added "shark bite" to add a bit of texture and keep it from being slippery. It is still very slippery. Definitely no running zone! I walk with trepidation when my feet are wet and a friend slipped and fell. I now have a mat at the stairs for traction. It is also very hot on the feet. I have photos under new construction.
    In-ground vinyl, 49 x 32' -19' -24' "dog bone" shape. 3.5' to 9' depth with 3' deep shallow cove.
    IC 60 salt generator, Intelliflo VS pump, Easy Touch panel, Laminar jets. Prowler Robotic, Stamped concrete.
    chessie6's Avatar
    East Hartford, Connecticut
    187
    It is slippery. I'm glad that we don't have children or have children over to swim for the most part. We coated it with shark bite which helped but not enough. I absolutely love the look of it and feel that it's worth it, but if we were very social people and had company over constantly I would really worry. It's just basically my husband and I (believe it or not, none of our friends like to swim) so we deal with it by wearing flip flops when out there and it's fine.
    Summer: 19 x 37 Pacific Graphex IG modified oval, aztec marine vinyl liner, 24,000 gal, 3.5 feet to 8 feet, 1 hp Hayward C4025 Swim Clear 4-cartridge filter, 12.5% Liquid Pool Shock for sanitizing, 1 super wide mouth skimmer, 4 returns (2 therapy jets in steps), Hayward Heat Pro heat pump, non-curved pool slide, 6' jump board, 8 ml blue solar cover, TF-100 test kit, had pink algae in 2010 Winter: Hot Springs Vista Spa, 500 gallons.
    Feb 2011
    Petaluma, Ca
    665
    I dont have any additives and no one has slipped yet. I've had many days with 4, 14 year old boys having fun, so far so good. I would agree that plain or brushed would have more grip but unless your running laps with wet feet around the pool I dont see a problem. Of all the people using the pool so far no one has commemted that the deck is slippery.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Aug 2011
    Clovis, Ca
    31
    Our new pool has nicely stamped concrete and it is not slippery at all. This I attribute to the fact that the builder really made deep impressions when he stamped it. Its not rough in any way nor is it a slick or slippery surface. It probably all depends on how it is done.
    Brand new IG gunite and plaster approx 18,500 gallons measured at fill from H2O meter.
    Clean and Clear Plus Cartridge 420 CU.FT.
    IntelliFlo VS-3050 VS+SVRS Pump
    Polaris 280 Cleaner
    Intellitouch automation
    TF100 Test kit
    Mar 2007
    San Rafael, CA USA
    12,082
    Our hardscape is troweled colored concrete and even though it is sealed every year with Glaze 'N Seal, it is not slippery except in the day or two right after sealing. The hardscape can be seen here and here. We avoided stamped concrete because it was more likely to be a trip hazard with its deeper ridges. Clearly for troweling, the final texture is very dependent on the quality of workmanship since this is done by hand.
    I am planning on stamped concrete in my build (1st quarter - Elegance 40). I visited the same pool at the builder's brother's house this weekend and the concrete looked great. They did seem to apply a lot of "pressure" to get deep impressions.
    Jan 2011
    Riverside, CA
    352
    It's raining here right now. I went outside and walked around on the new stamped concrete (we are not going to seal it).
    The areas of Stamped Concete with standing water are fairly slippery
    The areas that are wet, but all the standing water is gone are not very slippery
    I'd say that the 15+ year old brushed concrete out front is just as slippery with standing water on it
    The new brushed concrete with no standing water has the most traction (there isn't any standing water on the new brushed to test out)
    40x20 Free Form IG Pool (aprox 29,000 Gal, 140 Perimeter, depth 3'6"-7', Baja Shelf, 8x8 Free Form Spa) - Gunite Shell, Pebble Plaster Finish, Poured Concrete Coping - 3 Deep Heat Returns - Jandy LXi400 Gas Heater (400,000 Btu) - Jandy Variable Speed Pump JEP 2.0 - Jandy CL 600 Filter - HASA Liquidator - Jandy PDA 6 w/ Remote - 4x Jandy WaterColors Pool LEDs - 48" Gas Fire Pit - 6x Gas Tiki Torches - 12'x15' U-shaped BBQ Island (Firemagic Equipment)
    http://www.troublefreepool.com/new-p...ca-t28413.html
    bibeaud's Avatar
    Aug 2011
    P'Burg NJ
    73
    I have brushed concrete around our pool. I do not find it slippery at all. And yes, kids do run around the pool, especially when jumping in and out of the pool.
    11,000 Gal Trilogy "Utopia" Fiberglass Pool, 1HP Jandy Pump, Jandy CS200 Cartridge Filter, Raypak 199k BTU Heater, Liquidator, CMP Off-Line Chlorinator. Cleaners: Polaris 360, Blue Diamond, Poolvernuegen Pressure
    Our pool builder talked us out of stamped concrete saying that it would be very slippery. We agreed and went with colored, brush-finished concrete with a sealer. Unfortunately for us, the sealer they used turns the patio into an ice skating rink when it gets wet. We had 3 or 4 people take fairly nasty spills this summer. So it's not necessarily the just the concrete that's a factor but the sealer too.
    11,000 gal shaded pebbletech in ground with spa/spillover
    IntelliFlo VS+SVRS Pump
    Pentair Cartridge Filter
    Hayward Navigator Pro cleaner
    Rheem heater
    North Texas
    We have brushed coping and stamped concrete deck. So far it is not slippery at all. Even when wet. I had fiber added to the mix, so maybe that had something to do with it.
    21,500 Gunite Free Form ~ 18'X40', Sun Deck w/ foam jets auto valve, 3-Laminar Deck Jets w/ auto Valve, 1-Swim out, 3' to 8' deep, NPT Raku Tile
    All Sched 80 Pipe, Pentair Easy Touch control, Pentair pump and Sand Filter, Raypack Heater, White Plaster, Saline Chlorine Generation, Letro Platinum cleaner w/ booster
